Receiving multiple bytes?
Hello,
I'm working on a Remote Unit to report temperature using a DS1620 and door position using a proximity switch. The DS1620 requires a WORD variable and the door requires a BIT. Eventually this will include 5 Remote Transmitters but I'm working with only one now to get it functional.
I need to send the WORD and BIT from one Series 1 XBee to another. I've only seen references in the XBee Turorial to sending BYTES so I'm sending one WORD and one BYTE. See relevent code below
Transmitter code:
The code displays the correct information if only one of the SERIN statements is included (with the other SERIN statement commented out). But Switch just displays 0 with both statements in the code. I added separate Timeout statements but that didn't help.
I was hoping to receive both variables with one statement as follows, but that did not work either
Is it possible to send a WORD variable and decimal data using one SERIN statement?
falcon
Transmitter code:
tempIn VAR Word Switch VAR Byte SEROUT Tx, Baud, [DEC Switch, CR] SEROUT Tx, Baud, [TempIn]Receiver code:
main:
Switch VAR Byte
tempIn VAR Word
PAUSE 500
DEBUG "Configuring XBee...",CR
PAUSE 2000 ' Guard Time
SEROUT Tx,Baud,["+++"] ' Command mode sequence
SEROUT Tx,Baud,["ATD6 1,CN",CR] ' RTS enable (D6 1)
' Exit Command Mode (CN)
' ************** Main LOOP ******************************
PAUSE 500 ' 1/2 second pause to stabilize comms
DEBUG "Awaiting Byte Data...",CR
DO
SERIN Rx\RTS,Baud,1000,TimeOut1,[tempIn] ' Use Timeout to wait for byte
Timeout1:
SERIN Rx\RTS,Baud,1000,TimeOut2,[DEC Switch] ' Use Timeout to wait for byte
'GOTO Done ' Jump to done
Timeout2: ' If no data, display
Done:
DEBUG CRSRXY, 0, 2, TempIn, CR
DEBUG CRSRXY, 0, 5, DEC Switch, CR
goto main
SERIN Rx\RTS,Baud,1000,TimeOut,[TempIn, DEC Switch]
falcon
shouldn't that be reversed?
That was the problem. Both code lines are not always sent at the same time, but I was able to modify the sequence so that when both are sent the TempIn is always sent first.
falcon
