Displaying calculated numbers on Parallax parallel LCD
I am using the Parallax Experiment kit which comes with a parallel (not serial) LCD and the BS2. I am measuring resistance of a pot using the supplied 555 oscillator chip with the result stored as a Word variable (let's call it ResistanceValue). I view the result using DEBUG as a decimal (DEC) with 4 digits using DEBUG CRSRXY, 13, 2, DEC ResistanceValue, CLREOL. I would like to display this four digit value on the parallel LCD. I have no problem loading characters from a string (from the EEProm) such as "This is the resistance=" but have yet to work out how to add the number generated from the resistance.
:blank: Steve
:blank: Steve
This is not the most elegant method for converting an integer to a character byte array (string) but it works and should give you some ideas.
' {$STAMP BS2p} ' {$PBASIC 2.5} ' VARs number VAR Word char VAR Byte(4) 'Init number = 1234 Main: ' Get the individual numbers char(3) = number // 10 number = number - char(3) char(2) = number // 100 number = number - char(1) char(2) = char(2) / 10 char(1) = number // 1000 number = number - char(2) char(1) = char(1) / 100 char(0) = number / 1000 GOSUB PrintHex 'Conver the numbers to ASCII char(0) = char(0) + $30 char(1) = char(1) + $30 char(2) = char(2) + $30 char(3) = char(3) + $30 GOSUB PrintHex GOSUB Print END PrintHex: DEBUG HEX ?char(0), HEX ?char(1), HEX ?char(2), HEX ?char(3) RETURN Print: DEBUG STR char \4 RETURNMsgNums DATA "0123456789" ' store number characters in array
...Extract_Digits_from_number:
R1=Number//1000
R2=R1//100
R3=R2//10
R4=R3
R3=R2/10
R2=R1/100
R1=Number/1000
...then
READ (MsgNums + R1), char ' read a character from MsgNums
GOSUB LCD_Out ' write character at next cursor location
READ (MsgNums + R2), char ' read a character from MsgNums
READ (MsgNums + R3), char ' read a character from MsgNums
READ (MsgNums + R4), char ' read a character from MsgNums
X=12345
X DIG 4 returns the 10^4 decimal digit (1 in this case)
X DIG 0 returns the 10^0 decimal digit (5 in this case)
add 48 to that and you have the numeric ascii code to send to the LCD
X DIG 4 + 48
You can loop through the digits and suppress leading zeros or turn them into spaces if you want.
