SD Card Text Formatting When Writing
Hello,
I am curious as to the formatting of text files when writing to an SD card. Since I will be sending an instrument package pretty high up with a weather balloon, I am concerned about losing power (regarding the batteries and cold temperatures) and as a result losing data. In my code, which i have below, I mount the SD card, then enter a repeat loop in which i open the file, write to it, then close it....which essentially results in saving data on each loop cycle. However, my trouble comes with entering the data upon each iteration. Obviously if I simply enter the new data once re-opening the file, it will overwrite the previous data. I have tried using a carriage return, but this always overwrites what was previously written....and the new data is just written further down the page by some amount. I would like to use the position cursor function, but I have to use a variable for the Y position, and I can't get this to work. I have bolded the area of interest in my code below.
con
_clkmode = xtal1 + pll16x
_xinfreq = 5000000
DO = 10
CLK = 11
DI = 12
CS = 13
obj
sdfat : "fsrw"
pst : "parallax serial terminal"
pub demo | mount, n
pst.start(115200)
waitcnt(clkfreq*2 + cnt)
mount := \sdfat.mount_explicit(DO, CLK, DI, CS)
if mount <= 0
pst.str(string(13, "Failed to mount", 13))
abort
pst.str(string(13, "SD card is mounted.", 13))
n := 1
repeat 5
sdfat.popen(string("test.csv"),"w")
pst.str(string("opened", 13))
sdfat.pputs(string(2, 1, n, "work,right,now"))
sdfat.pclose
pst.str(string("closed",13))
n++
waitcnt(160_000_000 + cnt)
sdfat.unmount
pst.str(string(13, "Safe to remove.", 13))
As can be seen I am trying to use the local variable "n" for the Y position in the text file, however, the code won't compile. Any ideas/suggestions as to how I can write my data by opening and closing (i.e. saving) the file without overwriting my previous data? As always, any help would be greatly appreciated.
con
_xinfreq = 5000000
DO = 10
CLK = 11
DI = 12
CS = 13
obj
sdfat : "fsrw"
pub demo | mount, n
pst.start(115200)
if mount <= 0
abort
n := 1
repeat 5
sdfat.pclose
n++
sdfat.unmount
[B]sdfat.popen(string("test.csv"),"a") ' [COLOR=#0000ff]<---a not w![/COLOR][/B]Why not write a whole sector each time (512B)?
If you then perform a flush it will ensure that the data is written to the card, and you will not need to close and open the card all the time (I think - please check with Kye).
Otherwise, you could create a large blank file, and open it as update.
BTW I am not an expert on these drivers.
I have an enhancement for FSRW which allows to have a "swap"-file on the SD-card having any size you want. The access to that file is sector based, whereas you can address the locations to write to by byte-addresses. So, you could write your messages to different sectors by simply choosing the right address:
address := message_number % size_of_file * 512 + message_number / size_of_file * message_length
message_number -> guess no explaination needed here ... simply increment with each message written
size_of_file -> size of the file in bytes
message_length -> well ... I'd define a fixed message length which divides 512 without any rest. For example 8,16,32.... whatever fits to the max. length of a message you want to write
What happens then: Accessing a different sector with each message let's the virtual memory write the previous sector to SD card and read the actual one. This way you can only loose one message in case of failure of battery ...
You can read about virtual memory here: http://forums.parallax.com/showthread.php?117573-Virtual-Memory
data block, the FAT (if needed), and the directory are *all* updated.
So just write your data and flush when you are done and all should work
fine, even if power is lost.
(I do not know if this works with Kye's driver, but I tried to make my routines
mimic POSIX as much as possible, and in POSIX, flush makes sure the
data is on the disk and the metadata is updated.)
-tom
At 104 MHz you are violating the SD card spec of a maximum of 25 MHz clock to the SD card. My driver produces a 25 MHz clock output to the SD card at when the prop chip is running at 100 MHz.
BTW: MMC cards are not required to work above 20 MHz. So a prop chip running faster than 80 MHz using my driver might have problems with MMC cards.
The append method worked like a charm! It was too easy! Thank you so very much! Sorry for the delayed response.....and thank you everyone else for your responses!
