SayIt Module - Program Help — Parallax Forums
dehlendehlen Posts: 13
edited 2012-03-04 09:43 in General Discussion
Hey, i have a SayIt Module and the downloadable standard program is working fine.
Anyway i want to have the following commands:
Move forward X feets (0-10)
Move backward X feets(0-10)
Move left X feets (0-10)
Move right X feets (0-10)
Turn left 90,180,270,360 degrees
Turn right 90,180,270,360 degrees
Spin around
Go in Detection Mode
Actually i am very new to PBASIC and i don't know how to program this. I always get an error that my eeprom is full, because my code is very dirty i think.
Could be someone so kind and tell me how to program this ?
Thanks so much.
  • dehlendehlen Posts: 13
    edited 2012-03-03 04:59
    I found this post here: http://forums.parallax.com/showthread.php?106561-Voice-Controlled-Boe-Bot which does pretty much what i want. But i want the boe bot not to drive 5 feeds for example but 5 meters. So how can i change that ? And how do i have to setup my say it module ? Could you please help me ? Thanks
    edited 2012-03-04 07:01
    Nobody ? Please i really need your help.
    edited 2012-03-04 07:40
    You would need to structure your commands so that you end up with the correct portion of code running at the end of your voice commands
    this will involve a lot of voice recording and code portions.written, as there will be so many options. Unfortunately you cannot load a variable with this unit as I assume from your post you wish to do.
    edited 2012-03-04 07:57
    You mean i can't use wordlists like :
    Wordlist 1: Move, Turn
    Wordlist 2: Forward, Backward, Left, Right
    Wordlist 3: 1,2,3,4,5,6,7,8,9
    I have to make i this way: ??
    Move Forward 1
    Move Forward 2
    Move Backward 1
    edited 2012-03-04 08:05
    dehlen wrote: »
    Yes you can like that but as you see it will end in several options, what I was saying is you cannot just have one command for example move forward x steps and have the say it module just fill in the variable x
    you have to recvord and write all the necessary code and wordlists for all the options you feel you need and it maybe that's why you are running out of space?
    edited 2012-03-04 08:08
    Ah ok i see your point. Yes because of this number of options i get this "eeprom is full" error.
    I don't know how to fix that. I mean look at the link i posted. There is a guy who succeeded with this, so there must be a way to get this working.
    edited 2012-03-04 08:14
    dehlen wrote: »
    Move Forward 1
    Move Forward 2
    Move Backward 1
    You first group of wordlists if the way the SayIt works. You need to program the BS to switch wordlists though.
    Usually you'd start with the SayIt listening for the trigger word "Robot". Once it hears "Robot" it knows to listen for more commands.
    In you example, when "Robot" is heard, the BS would then switch the SayIt's wordlist to #1. While listening for words in wordlist #1, if the SayIt hears "Move", then your program would switch to wordlist #2 and listen for the direction. Once the direction is heard, the BS would switch the SayIt to wordlist #3 to determine how much to move.
    The main thing about all this is the SayIt itself isn't very smart. It doesn't know when to switch to different wordlists on its own; it needs the BS to tell it which wordlist to use.
    I see you're new to the forum. Welcome. Have you programmed your robot without the SayIt much? You want to make sure you know how to program the robot to do all these tasks without the SayIt before adding the complication of using the SayIt module as an input device.
    You mentioned you're new to PBASIC. You might want to get a little more comfortable with programming before adding the SayIt.
    It will also help us help you if you post the code you're working on. Phil made a little tutorial on how to use code tags. Here's the link.
    edited 2012-03-04 08:18
    I did exactly what you are describing. My Robot is in the first Wordlist. I say Move and the Robot goes into Wordlist too, because in this VRACTION i change VRGROUP = 2
    Then i say the direction and this works fine too and i set VRGROUP = 3 so he listens for the distance variable. But then i think i have to much cases and thats why my eeprom is full.
    Wait a minute i will write the code again like i had it and will post it here.
    Thanks again !
    edited 2012-03-04 08:26
    dehlen wrote: »
    He used his laptop to decode all the options and then just sent the appropriate command to the boe-bot.
    The voice recognition unit talked direct to his laptop whereas the Sayit talks via the boe, you may be able to read the serial data from the sayit into your pc but you would have to write some pc code to utilise this and then send the appropriate command back to the boe-bot.
    of course this could be achieved with a mic and voice recognition software also.
    Here is my code:
    ' {$STAMP BS2}
    ' {$PBASIC 2.5}
    ' COM Parameters
    COM_RX              PIN   0   ' rx pin
    COM_TX              PIN   2   ' tx pin
    COM_SPEED           CON   84  ' baud 9600
    COM_10MS            CON   10  ' 10ms unit
    ' Protocol Command
    CMD_BREAK           CON   "b" ' abort recog or ping
    CMD_SLEEP           CON   "s" ' go to power down
    CMD_KNOB            CON   "k" ' set si knob <1>
    CMD_LEVEL           CON   "v" ' set sd level <1>
    CMD_LANGUAGE        CON   "l" ' set si language <1>
    CMD_TIMEOUT         CON   "o" ' set timeout <1>
    CMD_RECOG_SI        CON   "i" ' do si recog from ws <1>
    CMD_RECOG_SD        CON   "d" ' do sd recog at group <1> (0 = trigger mixed si/sd)
    ' Protocol Status
    STS_AWAKEN          CON   "w" ' back from power down mode
    STS_ERROR           CON   "e" ' signal error code <1-2>
    STS_INVALID         CON   "v" ' invalid command or argument
    STS_TIMEOUT         CON   "t" ' timeout expired
    STS_INTERR          CON   "i" ' back from aborted recognition (see 'break')
    STS_SUCCESS         CON   "o" ' no errors status
    STS_RESULT          CON   "r" ' recognised sd command <1> - training similar to sd <1>
    STS_SIMILAR         CON   "s" ' recognised si <1> (in mixed si/sd) - training similar to si <1>
    ' Protocol arguments are in the range 0x40 (-1) TO 0x60 (+31) inclusive
    ARG_MIN             CON   64 ' 0x40
    ARG_MAX             CON   96 ' 0x60
    ARG_ZERO            CON   65 ' 0x41
    ARG_ACK             CON   32 ' 0x20    'TO READ more status arguments
    'Groups and Commands
    GROUP_2             CON   2    '(Command count: 5)
    G2_FORWARD                          CON   0
    G2_BACKWARD                           CON   1
    G2_LEFT                            CON   2
    G2_RIGHT                           CON   3
    GROUP_3             CON   3    '(Command count: 10)
    G3_1                                CON   0
    G3_2                                CON   1
    G3_3                                CON   2
    G3_4                                CON   3
    G3_5                                CON   4
    G3_6                                CON   5
    G3_7                                CON   6
    G3_8                                CON   7
    G3_9                                CON   8
    G3_10                               CON   9
    RES_ERROR           CON 255
    RES_TIMEOUT         CON 254
    RES_COMMFAIL        CON 253
    RES_BUILTIN         CON 32
    'Robot Constant
    VRLED               PIN   4
    'Global Variable
    VRA                 VAR   Byte
    VRA1                VAR   Byte
    VRGROUP             VAR   Byte
    VRCOMMAND           VAR   Byte
    VRVARIABLE          VAR   Byte
    ' Main Start
      INPUT COM_RX
      HIGH COM_TX
    Restart:
      LOW VRLED
      VRGROUP = 2
      DEBUG CR, "Setting up Robot... "
      'Wake up or stop recognition
      GOSUB VR_Wakeup
      DEBUG "awake... "
      'Set SI Language
      VRA1 = 3
      GOSUB VR_SetLanguage
      DEBUG "language ", DEC VRA1, "... "
      'Set 5 seconds timeout
      VRA1 = 5
      GOSUB VR_SetTimeout
      DEBUG "timeout ", DEC VRA1, "... "
      DEBUG CR, "Robot ready!"
    VR_Loop:
      DEBUG CR, "Robot in group ", DEC VRGROUP, " waiting for command... "
      LOW VRLED
      PAUSE 150
      IF VRGROUP > 0 THEN HIGH VRLED
      VRA1 = VRGROUP
      GOSUB VR_RecognizeSD
      '-- handle errors or timeout
      IF VRA1 = RES_ERROR THEN
        DEBUG "error"
        'try again in the same group
        GOTO VR_Loop
      ENDIF
      IF VRA1 = RES_TIMEOUT THEN
        DEBUG "timed out"
        VRGROUP = 2 ' back to trigger
        GOTO VR_Loop
      ENDIF
      IF VRA1 = RES_COMMFAIL THEN
        DEBUG "comm failed"
        'resync and try again
        GOSUB VR_Wakeup
        GOTO VR_Loop
      ENDIF
      '-- got a command
      VRCOMMAND = VRA1
      IF VRCOMMAND <= RES_BUILTIN THEN GOSUB VR_Action
      GOTO VR_Loop
    VR_Action:
      SELECT VRGROUP
        CASE GROUP_2
          SELECT VRCOMMAND
            CASE G2_FORWARD
             VRGROUP = 3
             VRVARIABLE = 0
            CASE G2_BACKWARD
             VRGROUP = 3
             VRVARIABLE = 1
             CASE G2_LEFT
             VRGROUP = 3
             VRVARIABLE = 2
            CASE G2_RIGHT
            VRGROUP = 3
             VRVARIABLE = 3
          ENDSELECT
        CASE GROUP_3
          SELECT VRCOMMAND
            CASE G3_1
            SELECT VRVARIABLE
            CASE 0
            DEBUG "Move Forward 1"
            CASE 1
            DEBUG "Move Backward 1"
            CASE 2
            DEBUG "Move Left 1"
            CASE 3
            DEBUG "Move Right 1"
            ENDSELECT
            CASE G3_2
             SELECT VRVARIABLE
            CASE 0
            DEBUG "Move Forward 2"
            CASE 1
            DEBUG "Move Backward 2"
            CASE 2
            DEBUG "Move Left 2"
            CASE 3
            DEBUG "Move Right 2"
            ENDSELECT
            CASE G3_3
              SELECT VRVARIABLE
            CASE 0
            DEBUG "Move Forward 3"
            CASE 1
            DEBUG "Move Backward 3"
            CASE 2
            DEBUG "Move Left 3"
            CASE 3
            DEBUG "Move Right 3"
            ENDSELECT
            CASE G3_4
              SELECT VRVARIABLE
            CASE 0
            DEBUG "Move Forward 4"
            CASE 1
            DEBUG "Move Backward 4"
            CASE 2
            DEBUG "Move Left 4"
            CASE 3
            DEBUG "Move Right 4"
            ENDSELECT
            CASE G3_5
              SELECT VRVARIABLE
            CASE 0
            DEBUG "Move Forward 5"
            CASE 1
            DEBUG "Move Backward 5"
            CASE 2
            DEBUG "Move Left 5"
            CASE 3
            DEBUG "Move Right 5"
            ENDSELECT
            CASE G3_6
             SELECT VRVARIABLE
            CASE 0
            DEBUG "Move Forward 6"
            CASE 1
            DEBUG "Move Backward 6"
            CASE 2
            DEBUG "Move Left 6"
            CASE 3
            DEBUG "Move Right 6"
            ENDSELECT
            CASE G3_7
              SELECT VRVARIABLE
            CASE 0
            DEBUG "Move Forward 7"
            CASE 1
            DEBUG "Move Backward 7"
            CASE 2
            DEBUG "Move Left 7"
            CASE 3
            DEBUG "Move Right 7"
            ENDSELECT
            CASE G3_8
              SELECT VRVARIABLE
            CASE 0
            DEBUG "Move Forward 8"
            CASE 1
            DEBUG "Move Backward 8"
            CASE 2
            DEBUG "Move Left 8"
            CASE 3
            DEBUG "Move Right 8"
            ENDSELECT
            CASE G3_9
              SELECT VRVARIABLE
            CASE 0
            DEBUG "Move Forward 9"
            CASE 1
            DEBUG "Move Backward 9"
            CASE 2
            DEBUG "Move Left 9"
            CASE 3
            DEBUG "Move Right 9"
            ENDSELECT
            CASE G3_10
             SELECT VRVARIABLE
            CASE 0
            DEBUG "Move Forward 10"
            CASE 1
            DEBUG "Move Backward 10"
            CASE 2
            DEBUG "Move Left 10"
            CASE 3
            DEBUG "Move Right 10"
            ENDSELECT
          ENDSELECT
      ENDSELECT
      RETURN
    '=== VR Routines ===
    ' Wake up:
    VR_Wakeup:
      TOGGLE VRLED
      VRA = CMD_BREAK
      SEROUT COM_TX, COM_SPEED, [VRA]
      SERIN COM_RX, COM_SPEED, 100*COM_10MS, VR_Wakeup, [VRA]
      IF (VRA <> STS_SUCCESS) THEN GOTO VR_Wakeup
      LOW VRLED
      RETURN
    ' Inputs:
    '   VRA1 = language index (0 = english, ...)
    VR_SetLanguage:
      VRA = CMD_LANGUAGE
      VRA1 = VRA1 + ARG_ZERO
      SEROUT COM_TX, COM_SPEED, [VRA1]
      SERIN COM_RX, COM_SPEED, 20*COM_10MS, VR_CommFailed, [VRA]
      VRA1 = VRA1 - ARG_ZERO
      'IF (VRA <> STS_SUCCESS) THEN GOTO VR_Wakeup
      RETURN
    ' Inputs:
    '   VRA1 = timeout (in ms, 0=forever, 255=default)
    VR_SetTimeout:
      VRA = CMD_TIMEOUT
      RETURN
    ' Inputs:
    '   VRA1 = SI knob (0=loosest, 2=normal, 4=tightest)
    VR_SetKnob:
      VRA = CMD_KNOB
      RETURN
    ' Inputs:
    '   VRA1 = SD level (1=easy, 2=default, 5=hard)
    VR_SetLevel:
      VRA = CMD_LEVEL
      RETURN
    ' Inputs:
    '   VRA1 = wordset (0=trigger)
    ' Ouputs:
    '   VRA1 = result (0-31=word, 32..=builtin, 253=comm err, 254=timeout, 255=error)
    VR_RecognizeSI:
      VRA = CMD_RECOG_SI
      GOTO VR_Recognize0
    VR_RecognizeSD:
      VRA = CMD_RECOG_SD
    VR_Recognize0:
      ' send Group/WS
      ' wait for answer
      SERIN COM_RX, COM_SPEED, 600*COM_10MS, VR_CommFailed, [VRA]
      IF VRA = STS_RESULT THEN
        ' send ack
        VRA = ARG_ACK
        ' wait for recognised command code
        SERIN COM_RX, COM_SPEED, 20*COM_10MS, VR_CommFailed, [VRA1]
      ELSEIF VRA = STS_SIMILAR THEN
        ' send ack
        VRA = ARG_ACK
        VRA1 = VRA1 - ARG_ZERO + RES_BUILTIN
      ELSEIF VRA = STS_TIMEOUT THEN
        VRA1 = RES_TIMEOUT
      ELSE
        VRA1 = RES_ERROR
      ENDIF
      RETURN
    VR_CommFailed:
      VRA1 = RES_COMMFAIL
      RETURN
    Of course instead of the DEBUG commands i would move the robot but for test purposes this is my code. Anyway i always get "eeprom is full" i think because of this high number of CASE commands.
    edited 2012-03-04 08:31
    dehlen wrote: »
    I just looked at the post you linked to. He was using a computer for the speech recognition. The computer was only sending three variables to the robot. His setup doesn't put much of a burden on the BS2.
    I do think the BS2 will be able to use the SayIt to control the BOE-Bot. It might take some careful programming not to use up all its EEPROM. I personally don't program Basic Stamps any more (I'm a Propeller fan) but there are lots of other forum members who could help you squeeze your code into a BS2. I'd suggest starting simple and then add more advanced features once you have the simple stuff working correctly.
    edited 2012-03-04 08:34
    Think of the command structure like the branches of a tree, the more branches you have the more twigs you end up with, the eeprom hasn't the capacity like the hard drive on your pc so if you wish to have all those options then you have to look at storing the structure on your pc rather than using the sayit, otherwise you need to cut down on the command set.
    edited 2012-03-04 08:37
    ok so if i want all these options it only works when my pc is on ? i could only use the robot whit all these options at home ?
    Anyway how could i complete this ?
    edited 2012-03-04 08:39
    Good to see your code.
    One thing I noticed was all the strings. Strings take up a lot of memory.
    Instead of
    use
    DEBUG "MF6"
    You could alternatively have the string
    "Move Forward "
    stored only a single time and reuse it in your debug statements and just add a unique ending as needed. I don't know how to do this with a BS2 but I bet others around here do.
    I bet there are other memory saving tricks that would help reduce the size of your code. Hopefully other forum members will point them out.
    edited 2012-03-04 08:44
    dehlen wrote: »
    I still think the BS2 can handle this project just fine (without needing a PC). Of course there will be a limit on how many tasks the BS2 can store, but I bet you could get your BOE-Bot to do a lot of stuff if you're careful with your programming.
    The problem I think you'll have is that the sayit module creates a BS2 template rater than talking to your pc via a serial gateway, it would mean that the onboard software on the sayit module would have to be hacked and that is probably something only the designer of the sayit would be able to help you with.
    Otherwise it's a case of going down the route like in the link you posted.
    edited 2012-03-04 08:58
    skylight wrote: »
    Do you mean hacking the SayIt's firmware?
    The SayIt will work fine independent of the PC. You don't even need a PC to program in custom words. The PC software for the SayIt just sends serial commands to the SayIt module (via the bridge program). A microcontroller could also send these same commands. The PC software just make it more convient to program the custom words in the SayIt by letting the user interact with an easy to use GUI that takes care of sending the proper serial commands for you.
    The PC software also generates a PBASIC template to help get you started with the programming process. The template isn't very smart. The user still needs to do a lot of work to make a useful PBASIC program from the template.
    This is a great project. The BS2 can do this! It will only need the PC for editing and loading the program. It will not be dependent on the PC when it's roaming around listening for your commands. (Because of servo noise, the BOE-Bot might need to be standing still to hear commands.)
    edited 2012-03-04 09:03
    Duane Degn wrote: »
    This is a great project. The BS2 can do this! It will only need the PC so you can type your program. It will not be dependent on the PC when it's roaming around listening for your commands.
    Not the way the OP wants to do it, with so many commands and options he is running out of memory, the debug commands he mentioned above I believe are not in his final program but were there to prove the structure was working ok.
    The suggestion to hack the firmware was so that it could be used like the speech recognition unit he posted in his link, as it stands the Sayit would not be able to do what he wants unles he cuts back on his command list.
    edited 2012-03-04 09:11
    Ok i cut the commands to feet 1-5 not from 1-10 and now my eeprom isn't full anymore. Anyway how can i deliver the variable to my method ?
    I check the cases and for example i am in the case forward 1 feet. So i write in this case GOSUB MForward
    The MForward Method looks like this:
    MForward:  FOR counter = 1 TO ((var3-48) * 70)
        GOSUB Forward
        PAUSE 20
      NEXT
      RETURN
    And the Forward method like this:
    Forward:
      PULSOUT 13, 850
      PULSOUT 12, 650
      RETURN
    But how does the method MForward get the value for var3 ?
    Thanks !
    edited 2012-03-04 09:14
    skylight wrote: »
    <snip>
    Really? You don't think a BS2 could handle these commands?
    dehlen wrote: »
    Spin around
    I just find that hard to believe. As I mentioned, I don't use Basic Stamps anymore but I still think the BS2 could handle this project.
    Any other BS2 users around that have an opinion about this? Chris, Mike, Tracy, erco, PJ?
    edited 2012-03-04 09:16
    dehlen wrote: »
    MForward:  FOR counter = 1 TO [SIZE=2][B]((var3-48)[/B][/SIZE] * 70)
        GOSUB Forward
        PAUSE 20
      NEXT
      RETURN
    Forward:
      PULSOUT 13, 850
      PULSOUT 12, 650
      RETURN
    Thanks !
    That's what I was saying beforehand you can't insert a value into the vaiable like that.
    You will have to record a command for each value of var 3 to do something for each option you would fill in the program code in the template, it's laborius but i'm afraid it's the only way
    So to summarize you would have forward code for 1 foot, 2 foot, 3 foot etc.......
    you could get the relevant code to say that var 3 is this value but it would still probably have the same amount of commands and code snippets to achieve the same result.
    edited 2012-03-04 09:21
    i know that the calculations for the FOR Loop is wrong .... i will correct that, but i really need how to deliver var3 to the function.
    edited 2012-03-04 09:25
    Duane Degn wrote: »
    I'm not saying the BS2 cannot handle the commands it's more a case of how many commands.
    edited 2012-03-04 09:28
    oh sorry i got it.... now everything works just fine. Thanks a lot for your help !
    Glad you got it to work.
