28317 Linescan Sensor Module — Parallax Forums
B.ASHISHB.ASHISH Posts: 28
edited 2012-04-05 09:50 in Propeller 1
I want to interface the TSL 1401 -DB LINE SCAN SENSOR MODULE using the Propeller microcontroller.I used the datasheet of TSL1401R-LF and this is the code which I used.
CON
resolution = 256
_clkmode = xtal1 + pll16x
_clkfreq = 80_000_000
BASE_PIN=0
OBJ
pst : "Parallax Serial Terminal"
VAR
long Stack[16]
PUB main | i,value
DIRA[0..2]:=%110
pst.Start(115_200)
cognew(clk,@Stack)
pst.Str(String("Enter a decimal value: "))
repeat
OUTA[0]~~
waitcnt(clkfreq*0.0000001+cnt)
outa[0]~
repeat i from 1 to 128
value := INA[2]
pst.dec(value)
waitcnt(clkfreq*0.0000003232421875+cnt)
pst.dec(value)
PUB clk
repeat
outa[1]~~
waitcnt(clkfreq*0.000000125+cnt)
outa[1]~
But it is displaying 83886097.Instead it should display binary values based on the intensity of light,So please help me in making this sensor to run correctly.
    edited 2012-03-03 08:10
    B.ASHISH,
    Welcome to the forum!
    Okay, first things first:
    Please edit your post.
    Also, I notice that you have four other threads started with the same question. I've had them deleted so we can focus on this one.
    Regarding the obvious issues in your code:
    1. You can't use floating-point values in your code the way you've done. You have to do something like clkfreq / n, where n is an integer. All arithmetic in Spin is done with 32-bit signed integers.
    2. But, more to the point, the waitcnts in your program are unnecessary and should be removed. Spin's overhead adds way more time than is needed by the sensor chip.
    3. You're addressing value as an array, but it hasn't been declared as such. Declare value in the VAR section as an array, instead of as a local variable.
    Which Propeller platform are you using with the TSL1401-DB? If it's the Propeller Backpack, I can upload a driver object for you that will simplify your programming.
  • B.ASHISHB.ASHISH Posts: 28
    edited 2012-03-05 01:10
    Sir,I have changed as told by you .Here it is.The Propeller Microcontroller IC is P8x32A-044 0739.
    CON
    OBJ
    VAR
        long Stack[16]
      byte  value[128]
    -----------[ Public Methods ]-------------------------------------------------
    PUB main  | i
    DIRA[0..2]:=%110
    pst.Start(115_200)
    cognew(clk,@Stack)
    repeat
       OUTA[0]~~
        waitcnt(clkfreq/10000000+cnt)
        outa[0]~
           value[i] := INA[2]
           pst.dec(value[i])
         waitcnt(clkfreq/5988304+cnt)
       pst.dec(value[i])
    PUB clk
    repeat
       outa[1]~~
       waitcnt(clkfreq/8000000+cnt)
       outa[1]~
    But the Parallax serial Terminal is not displaying anything.
    The clock frequency of the microcontroller is 80MHz and that which is required for this sensor is 8MHz.
    I think,there is a problem with the synchronisation.I followed the timing Diagram of TSL1401-LF datasheet.
    edited 2012-03-05 01:21
    waitcnt can't use such small values.
    Change your waitcnt values to something larger. Such as:
    waitcnt(clkfreq / 1000 + cnt)
    Each of the very short waitcnt values you used will cause the Propeller to wait about 54 seconds as the 32-bit clock rolls over.
    The smallest waitcnt valve is larger than 700 but smaller than 1000 (I don't recall the exact number).
    So this would also work.
    waitcnt(1000 + cnt)
    The above will wait for 12.5 us @ 80MHz (plus some extra time for code overhead).
    Edit: It looks like you're trying to generate a very fast pulse. The easiest way to do this is with counters. There's a section in the Propeller Education Kit about counters that should help. The PEK can be found in the "help" menu of the Propeller Tool.
    edited 2012-03-05 07:02
    As I stated before, just get rid of the waitcnts altogether. They are not necessary. Spin's overhead provides provides more than enough built-in delays for the sensor timing. Also:
    1. You're not using your clk method, so neither SI nor the output data are being clocked.
    2. I would not include pst.dec(value) inside the read loop, since it will slow it down too much. You already have a separate loop after the azquisition loop. Just use that one to read out your data.
    3. You have not made adequate provision for the exposure time. I would recommend a dummy acquisition loop, followed by a delay, before the actual acquisition loop. The exposure time would be the interval between pulsing SI.
    Which board are you using with your Propeller chip?
  • turbosupraturbosupra Posts: 1,088
    edited 2012-03-05 10:34
    I've learned the hard way that the pst really slows things down as far as prop time is concerned (not in human time though) so what I have done is had the main thread output pst values and a cog run the object by itself (like you did, but only have main report values to the pst) but I only do this in slow motion, and by that I mean when I'm testing at less than 10hZ, otherwise the program fails randomly due to the pst being a bottle neck.
    I also think your stack is too small, I make my stack 100 now at a minimum, because I have seen random issues with that as well.
    I'm not sure exactly what you are trying to do, but I have had pst issues like this and learned what I'm telling you the hard way ... take this code with a grain of salt as untested (it will compile), but the format might help you.
    CON
    OBJ
    VAR
      long Stack[100]
      long i
      byte  value[128]
    '-----------[ Public Methods ]-------------------------------------------------
    PUB main  | timeStamp, waitTime
    DIRA[0..2]:=%110
    pst.Start(115_200)
    cognew(clk,@Stack)
      timeStamp := cnt
      waitTime := (clkfreq/10)
        pst.dec(value[i])
    PUB clk | timeStamp, waitTime
      timeStamp := cnt
      repeat
        outa[1]~~
        waitcnt(timeStamp += waitTime )
        'waitcnt(clkfreq/8000000+cnt)
        outa[1]~
    PUB otherMethod | timeStamp, waitTime, waitTime2
      timeStamp := cnt
      waitTime2 := (clkfreq/100)
      repeat
        OUTA[0]~~
        outa[0]~
          value[i] := INA[2]
          'pst.dec(value[i])          ' This should be in the main method only, or a separate cog
          waitcnt(timeStamp += waitTime2 )
    edited 2012-03-06 08:22
    Sir,this code is displaying 61 zeroes and a 2 in the pst.
    edited 2012-03-06 08:30
    Sir,the Propeller Board used has a Product Number ​555-32100.
    edited 2012-03-06 08:43
    My code was a template for you to build off of, not a final solution as I wasn't really clear as to what you wanted.
    Maybe you can describe in detail what you want to see as an output (or to monitor), and I can tweak my code to represent that better.
    B.ASHISH wrote: »
    edited 2012-03-06 10:17
    Since I don't have the light sensor you have, I can only write generic code.
    This code example polls 2 pins that I have LED's alternating on and off, and checks there states.
    You'll see that I have 1 cog controlling the two pins alternation, and I have the first cog (main) monitoring it and updating the pst terminal window with the state. You can tweak this code so that the clk loop controls the light sensor, or updates a global variable with the light sensors state, and then the first cog (main) checks that global variable or pin and prints update values to the pst as fast as it can. The pst can only do a maximum of 115000 bits per second, so lets say that you only send the actual numerical value plus a carriage return, that's 3 bits plus a stop bit, so that's a theoretical maximum amount of 28800 updates to the pst per second.
    Either way, if you have the data changing each microsecond, which is a million times a second, you can easily see that at absolute best, the pst could only theoretically catch 1 out of every 34.7 of the 1,000,000 updates per second. Make sense?
    CON
    OBJ
    VAR
    long clkStack[100]
    PUB main | i, value, timeStamp, waitTime1, waitTime2, waitTime3
    'DIRA[0..2]:=%110
      i := 0                        ' initialize your local variables to 0
      value := 0                    ' initialize your local variables to 0
      waitTime1 := (clkfreq/2)      ' this is a random delay that I chose for demonstration
      waitTime2 := (clkfreq/10)     ' this is a random delay that I chose for demonstration
      waitTime3 := (clkfreq/100)    ' this is a random delay that I chose for demonstration
      pst.Start(115_200)            ' start your serial terminal object
      cognew(clk, @clkStack)        ' assign your oscillation method to a new cog
      'pst.Str(String("Enter a decimal value: "))
      pst.Str(String("Starting "))  ' for sanitys sake when you are waiting for values to start appearing on the pst
      pst.Str(string(pst#NL))       ' a carriage return after printing something to the pst
      timeStamp := cnt              ' sync a variable with the cnt, I always do this right before starting the loop
      repeat
        pst.Dec(ina[16])            ' print the state of the pin to the pst
        pst.Dec(ina[17])            ' print the state of the pin to the pst
        waitcnt(timeStamp += waitTime2)                     ' pause for whatever time delay, this may not be needed as the pst is slow
     { repeat 'i from 1 to 128
        value[i] := INA[16]
        pst.dec(value[i])
        waitcnt(timeStamp+waitTime2)
        value[i] := INA[17]
        pst.dec(value[i])
        waitcnt(timeStamp+waitTime2) }
     { repeat i from 1 to 128
      pst.dec(value[i])  }
    PUB clk | timeStamp, waitTime1, waitTime2, waitTime3
      Dira[16]~~                    ' initialize the pin direction
      Outa[16]~                     ' initialize the pin state
      Dira[17]~~                    ' initialize the pin direction
      Outa[17]~                     ' initialize the pin state
      waitTime1 := (clkfreq/2)      ' initialize local variables
      waitTime2 := (clkfreq/10)     ' initialize local variables
      waitTime3 := (clkfreq/100)    ' initialize local variables
      repeat
        outa[16]~~                                          ' set pin high
        waitcnt(timeStamp += waitTime2)                     ' wait for a predetermined time between oscillations
        outa[16]~                                           ' set pin low
        outa[17]~~                                          ' set pin high
        outa[17]~                                           ' set pin low
    B.ASHISH wrote: »
    edited 2012-03-06 12:03
    Since I had not done so before, I took some time to come up with a demo program for the TSL1401-DB, written entirely in Spin. Since it does not rely upon any kind of analog-to-digital conversion, it should work on any Propeller platform. The TSL1401's analog output is simply compared with the Propeller's input logic threshold, producing either a 0 or a 1 for each pixel. Here's the program:
    '':::::::[ TSL1401-DB Spin Driver ]::::::::::::::::::::::::::::::::::::::::::::
    │   TSL1401-DB Driver writtin in Spin   │
    │(c) Copyright 2012 Bueno Systems, Inc. │
    │   See end of file for terms of use.   │
    This program drives the TSL1401-DB completely from Spin. The sensor's analog output
    is thresholded against the Propeller's input logic threshold (nominally Vdd / 2) to
    produce either a 0 or a 1 for each pixel. The pixels are output continuously to
    the Parallax Serial Terminal in the form ....11111....11..., etc., where the 1's
    correspond to bright pixels, the periods to dark pixels.
    Each scan begins with a separate integration sequence to flush out pixels integrated
    during the output phase and to integrate over an accurate exposure time, given by
    EXPTIME (in usec).
    CON
      _xinfreq      = 5_000_000
      'Define pine:
      AO            = 0             'TSL1401 analog output.
      SI            = 1             'TSL1401 start integrate and readout.
      CK            = 2             'TSL1401 clock.
      'Define exposure time (usec):
      EXPTIME       =  16667
    VAR
      byte  pixels[128]             'Pixel array.
    OBJ
      sio   :       "Parallax Serial Terminal"
    PUB  start | expticks, i
      sio.start(38400)                                      'Initialize serial output.
      dira[CK]~~                                            'Set control pins as outputs.
      dira[SI]~~
      expticks := clkfreq / 1000 * EXPTIME / 1000           'Convert exposure time to cnt ticks.
      frqa := frqVal(4_000_000)                             'Set up frqa for 4 MHz clock burst.
      repeat
        waitcnt(i := cnt + 1000)                            'Sync with cnt.
        ctra~                                               'Dummy for same as following waitcnt.
        outa[SI]~~                                          'Clock in SI pulse.
        outa[CK]~~
        outa[SI]~
        outa[CK]~
        phsa~                                               'Make sure burst starts with a low.
        ctra := %00100 << 26 | CK                           'Start counter that outputs the burst on CK.
        waitcnt(i + expticks)                               'Wait for exposure time to complete.
        ctra~                                               'Turn off bursts.
        outa[CK]~~
        outa[SI]~
        outa[CK]~
        repeat i from 0 to 127                              'Begin reading out 128 pixels (0 or 1).
          pixels[i] := ina[AO]                              '  Get pixel from input logic threshold on AO.
          outa[CK]~~                                        '  Pulse CK.
          outa[CK]~
        sio.char(1)                                         'Move cursor to beginning of line.
        repeat i from 0 to 127                              'Begin reading out 128 pixels.
          sio.char("." + pixels[i] * 3)                     '  Output "." for 0; "1" for 1.
    ''=======[ Tracy Allen's frqx Calculator ]=====================================
    PRI frqVal(freq) : frqx
    '' Return f = freq / clkfreq * 2^32, given freq < clrfreq, freq < 2^30
      repeat 32                                             ' 32 bits
         freq <<= 1
         frqx <<= 1
         if freq => clkfreq
            freq -= clkfreq
            frqx++
    ''=======[ License ]===========================================================
    &#9484;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9488;
    &#9474;                            TERMS OF USE: MIT License                                 &#9474;
    &#9500;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9508;
    &#9474;Permission is hereby granted, free of charge, to any person obtaining a copy of this  &#9474;
    &#9474;software and associated documentation files (the "Software"), to deal in the Software &#9474;
    &#9474;without restriction, including without limitation the rights to use, copy, modify,    &#9474;
    &#9474;merge, publish, distribute, sublicense, and/or sell copies of the Software, and to    &#9474;
    &#9474;permit persons to whom the Software is furnished to do so, subject to the following   &#9474;
    &#9474;conditions:        &#9474;
    &#9474;        &#9474;
    &#9474;The above copyright notice and this permission notice shall be included in all copies &#9474;
    &#9474;or substantial portions of the Software.                                              &#9474;
    &#9474;        &#9474;
    &#9474;THE SOFTWARE IS PROVIDED "AS IS", WITHOUT WARRANTY OF ANY KIND, EXPRESS OR IMPLIED,   &#9474;
    &#9474;INCLUDING BUT NOT LIMITED TO THE WARRANTIES OF MERCHANTABILITY, FITNESS FOR A         &#9474;
    &#9474;PARTICULAR PURPOSE AND NONINFRINGEMENT. IN NO EVENT SHALL THE AUTHORS OR COPYRIGHT    &#9474;
    &#9474;HOLDERS BE LIABLE FOR ANY CLAIM, DAMAGES OR OTHER LIABILITY, WHETHER IN AN ACTION OF  &#9474;
    &#9474;CONTRACT, TORT OR OTHERWISE, ARISING FROM, OUT OF OR IN CONNECTION WITH THE SOFTWARE  &#9474;
    &#9474;OR THE USE OR OTHER DEALINGS IN THE SOFTWARE.                                         &#9474;
    &#9492;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9472;&#9496;
    Enjoy!
    edited 2012-03-07 04:09
    Sir this is displaying a series of ............................................ in pst.
    edited 2012-03-07 08:24
    Make sure you have the sensor module connected correctly and that the pin assignments in the CON section of the program agree with your actual hardware setup. Also make sure that you have enough light. Aim the camera at a light bulb or window.
    edited 2012-03-29 05:13
    Sir the sensor is running but repeatability in the readings is not achieved.
    The 128 pixels scan is changing continuously changing with every press of the enter key.
    What is the range of the sensor? and what about the focal length ?Is there an optimum focal length to achieve correct readings?
    I actually want to calculate the width of an object using this sensor module and also the orientation of the object with respect to this sensor module.
    I used a 3cm wide black strip on a white background for the experiments.Please help me out,to stabilise the readings of a fixed object and finally to find the width of the object.
    edited 2012-03-29 09:02
    It sounds as if your scene is being illuminated with fluorescent lighting. Correct? If that's the case, be sure that your exposure time is a multiple of of the mains frequency period, i.e. 16.6666 msec for 60 Hz; 20 msec for 50 Hz. Also, never, never never rely upon ambient lighting for illumination. You will need to provide controlled lighting that's much brighter than the ambient for consistent measurement results. You will also get the best results when the lens is properly focused.
    edited 2012-04-03 09:53
    Sir, can you please suggest me some methods to find the width of an object using Linescan sensor data( It displays the 128 pixel scan of 1s and 0s,where 1 signifies a light colored object including white and 0-a dark object.)
    I am using a white paper with a BLACK STRIP OF 3CM WIDTH and observing the readings.
    I want the object's orientation with respect to the sensor module
    edited 2012-04-03 10:04
    The easiest way to measure the width of a dark-colored object is simply to count the number of zero pixels in the field of view. This presupposes, of course, that there are no extraneous dark pixels outside the boundaries of the subject. In your case (a black strip on white paper), there shouldn't be.
    edited 2012-04-04 08:53
    Sir ,please tell me how to adjust the focal length.How to get the optimum focal length?
    Repeatability in the readings is not being achieved.
    I have kept a black strip on a white background .
    The black strip is exactly in front of the sensor module.
    But 0s are being displayed in a corner.
    It should display 11111111111111111110000000000011111111111111111
    but sometimes it displays 111111111000011111111101101101111111111 and not in the exact position.
    Please help me Sir in solving this problem.
    edited 2012-04-04 09:49
    The lens that comes with the TSL1401-DB has a fixed 8mm focal length. You can't adjust it. You can adjust the focus, however, by screwing the lens in and out of its holder (in for distant subjects, out for near subjects).
    This is typically a function of lighting. If the lighting is uncontrolled, flickery, or inadequate, you cannot get consistent results from any vision system. What are you using to illuminate your subject?
    This may be due to vignetting, caused by the "cosine effect" (see the docs for an explanation), or it could be due to inadequate lighting near the edges of your field of view.
    BTW, which program are you using? The one I provided displays 11111111........11111111, not 111111110000000011111111. It may be that, in your situation, you need more than just a simple logic threshold to compare the pixel values to. You might consider a board with built-in sigma-delta ADC capabilities, such as the Propeller Backpack or even the QuickStart (which requires some soldering to activate ADC). With full ADC, you will be able to incorporate edge enhancement, which can compensate for effects such as vignetting and, to a lesser extent, variable lighting.
    edited 2012-04-05 09:41
    Sir,this is my code.
    [EDIT/]
    CON
    AO = 15 ' Camera Analog Output
    SI = 14 ' Camera SI
    CLK = 13 ' Camera clock
    LED = 3
    OBJ
    Sio : "FullDuplexSerialPlus"
    Ls : "TSL1401Binary"
    VAR '
    byte image[128] ' image values
    long exp ' exposure time in milli seconds
    Pub Main | i
    Initialize
    exp := 100 ' exp milliseconds
    repeat
    Ls.LedOn
    Ls.GetImage(@image, exp) ' Get an image
    Ls.LedOff
    Sio.tx(0)
    Sio.str(@ruler1) ' Print rulers
    Sio.tx(13)
    Sio.str(@ruler2)
    Sio.tx(13)
    Sio.dec(image) ' Print image
    Sio.tx(13)
    Sio.tx(13)
    Sio.dec(Ls.CountPixels(0, 127, Ls#DRK, @image)) ' Count dark
    Sio.tx(9)
    Sio.dec(Ls.CountPixels(0, 127, Ls#BRT, @image)) ' Count light
    Sio.tx(13)
    Sio.dec(LS.FindPixel(0, 127, LS#DRK, LS#FWD, @image)) ' Find dark pixel forward
    Sio.tx(13)
    Sio.dec(LS.FindEdge(0, 127, LS#LTOD, LS#FWD, @image)) ' Find light to dark edge forward
    Sio.tx(9)
    Sio.Dec(Ls.FindEdge(0, 127, LS#LTOD, LS#BKWD, @image)) ' Find light to dark edge backward
    Sio.tx(13)
    Sio.Dec(Ls.FindEdge(0, 127, LS#DTOL, LS#FWD, @image)) ' Find dark to light edge forward
    Sio.tx(13)
    i := LS.FindLine(0, 127, LS#DRK, LS#FWD, @image) ' Find dark line forward
    Sio.Dec(i >> 16)
    Sio.tx(9)
    Sio.Dec((i & $FF00) >> 8)
    Sio.tx(9)
    Sio.Dec(i & $FF)
    Sio.tx(13)
    i := LS.FindLine(0, 127, LS#DRK, LS#BKWD, @image) ' Find dark line backward
    Sio.Dec(i >> 16)
    Sio.tx(9)
    Sio.tx(9)
    Sio.Dec(i & $FF)
    repeat until !Sio.rxcheck ' wait for key from terminal
    PUB Initialize
    {{ Initialize the pins direction and state. Must be called once. }}
    Sio.start(31,30,0,115200) ' Rx,Tx, Mode, Baud
    Ls.Init(AO, SI, CLK, LED)
    DAT
    ruler1 byte " 1 2 3 4 5 6 7 8 9 10 11 12", 0
    ruler2 byte "01234567890123456789012345678901234567890123456789012345678901234567890123456789012345678901234567890123456789012345678901234567", 0
    [/EDIT]
    Please edit your post, in order to preserve indentation. Also, you've said nothing so far about what kind of illumination you're using.
