Any word on the Stingrays and when they will be back in stock?
...Patiently waiting for the mailperson with a box.
On a different subject, and I am sure this will not get any visibility with this thread heading, but this is my first attempt at PASM, it simulates a ping sensor. Appreciate any feedback.
{PING_Spoof}
CON
_CLKMODE = XTAL1 + PLL16X 'Set to ext low-speed crystal, 16x PLL
_XINFREQ = 5_000_000 'Frequency on XIN pin is 5 MHz
VAR
long Stack1[9] 'Stack space for new cog
byte Cog 'Hold ID of cog in use, if any
long counter
PUB Start
Stop
Cog := cognew(@WaitHigh, 0)
PUB Stop
{{Stop toggling process, if any.}}
if Cog
cogstop(Cog~ - 1)
PUB Active: YesNo
{{Return TRUE if process is active, FALSE otherwise.}}
YesNo := Cog > 0
DAT
org 0
WaitHigh or dira, PinMask 'Makes Pin Output
andn outa, PinMask 'Makes Pin Low
andn dira, PinMask 'Makes Pin Input
test PinMask, ina wz
if_z jmp #$-1
if_nz jmp #$-1
jmp #Toggle
Toggle or dira, PinMask 'Makes Pin Output
or outa, PinMask 'Makes Pin High
mov Time, cnt
add Time, #9
waitcnt Time, Delay
waitcnt Time, Delay
jmp #WaitHigh
PinMask long |<23
Delay long 141_000
Time res 1
