USB scope — Parallax Forums
USB scope
RS_JimRS_Jim Posts: 1,775
edited 2012-03-02 04:35 in General Discussion
I have an original Parallax usb scope currently connected to my desktop running under winxp. It works great. Now I have a project that I need to run the scope on my laptop which runs on (ugh) vista. First is the software compatible? Second since it has been replaced by the props cope, I haven't been able to find the software. Next I am going to have to measure some pulses that are about 50 volts. Since the scope is rated at 20 volts max I am going to have to use a voltage divider on the scope inputs. Any suggestions for resistance values would be welcome.
Thanks for the help, I need to scope the output of my saltwater pool cl generator as cl levels are excessive. I suspect that the output is always generating a full width pulse rather than narrower pulses when the cl leval is turned down. I need proof of my theory so I can go back on Hayward as the control board is less than a year old and has always generated excessive levals of cl.
RS_Jim
    edited 2012-03-01 08:11
    The software is availlable here
    BTW - Happy Birthday!
    edited 2012-03-01 08:26
    Jim,
    You will need to use version 5.1.1 for Vista.
    Ditto on the HBD!
    Jim
  • RS_JimRS_Jim Posts: 1,775
    edited 2012-03-01 10:28
    Thanks for the link Ron. And thanks for bdw from Ron and Jim. at my age it is wonderful to to still be fully functional.
    After a little consideration I think I will use 5 meg and 1meg as my input divider which will give me about 5 volts available at the probe input and will not load the circuit.
    I will mark this solved. If I can figure out how to mark it!
    Jim
    edited 2012-03-01 10:50
    RS_Jim wrote: »
    Jim
    Just edit the original message (might need to be Advanced mode) and from the dropdown, select "Solved"
    Thanks Ron!
    Jim
