Understanding the BS2pe AVR co- processors' commands.
Hi ya all,
I'm working with a "BS2pe" mo- board and I'm having a hard time understanding the AVR co- processors command protocol. I have a strong background in the Hex, octal, decimal and binary numbering systems. So I'm probably making this a lot harder than it needs to be. I've petty much digested the "AVR Firmware: GPIO, version 3 manual. (all nine pages). Can anyone tell me where I can find some more info that might help me understand these owio commands?
Dean
Dean
Check the PBASIC manual for details about how OWIO works. Next, take a look at some of the AVR example calls. Then, if you have any questions about a specific command found in the examples, return here to ask, and I'll try to help.
I've been using source codes written by you and a few other people. They work --- but I don't know what I,m doing.
Take the command " OWOUT 10, 0, [$10]" . According to the manual this statement will write a digital one to port 2.
It doesn't say which AVR it will use. I'm assuming the 10 is P10 of the BS2pe that feeds AVR "A" but I'm not sure
because 10 is also a binary "2". How does this statement designate which AVR (A or
THANKS AGAIN FOR YOUR TIME.
Dean
The second argument is the mode, which you can read about in the PBASIC manual. "0" specifies no reset, byte mode, low speed. All interaction with the AVR has to be low-speed byte mode. But you can use modes that include a reset.
The data that gets sent is whatever appears between brackets []. "$10" is 16 in hexadecimal.
