ping))) for double feed detection
I'm wondering if there is any way to split the emitter and sensor in the ping so that it can be used for double-feed detection? I'd want to determine how much attenuation there was in the signal after it had passed through a gap that might contain one or more sheets of paper.
Or could you use two by disabling the sensor on one and the emitter on the other?
Welcome to the forum!
You can disable either transducer in the Ping))) by covering it, but that will not help you with your app. The reason is that the Ping))) responds digitally to a pulse's time-of-arrival. There is no indication of signal strength.
Mr. Pilgrim,
Can you elaborate on this? I'm not "gettin' it".
Thanks much.
Got it - thanks!
