GPS PMB 688 With Atmega 16/32
hello all.
As a part of my project I have to interface parallax PMB 688 GPS receiver with atmega 32 the microcontroller that I am using..
I tried to retrieve NMEA sentences from it..but in my LCD (16*2) i am getting wrong information..
I have connected PMB 688 GPS
->its red colour wire to 5V
->its black colour wire to GND
->its yellow colour wire to RxD pin of Atmega 32..
Here is my code...
can anybody tel me what is wrong with it??please..
// Program to get latitude and longitude value from GPS modem and display it on LCD:
#define F_CPU 16000000UL
#include<avr/io.h>
#include<util/delay.h>
#define USART_BAUDRATE 4800
#define BAUD_PRESCALE (((F_CPU / (USART_BAUDRATE * 16UL))) - 1)
#include "lcd.c"
void usart_init();
unsigned int usart_getch();
unsigned char value,i,lati_value[15],lati_dir, longi_value[15], longi_dir, alti[5] ;
int main(void)
InitLCD(LS_BLINK|LS_ULINE); //initialization of LCD
_delay_ms(50); // delay of 50 mili seconds
LCDWriteString("we at");
LCDCmd(0xC0);
usart_init(); // initialization of USART
while(1)
value=usart_getch();
if(value=='$')
if(value=='G')
if(value=='P')
if(value=='G')
if(value=='G')
if(value=='A')
if(value==',')
while(value!=',')
lati_value[0]=usart_getch();
value=lati_value[0];
for(i=1;value!=',';i++)
lati_value=usart_getch();
value=lati_value;
lati_dir=usart_getch();
while(value!=',')
longi_value[0]=usart_getch();
value=longi_value[0];
longi_value=usart_getch();
value=longi_value;
longi_dir=usart_getch();
LCDCmd(0x01); //clear display
_delay_ms(1);
LCDCmd(0x80); //force cursor to begin on 1st line
_delay_ms(1000);
LCDWriteStringXY(0,0,"Lat:");
i=0;
while(lati_value!='\0')
LCDWriteInt(lati_value,1);
i++;
LCDWriteString("-");
LCDWriteInt(lati_dir,1);
LCDCmd(0xC0);
LCDWriteStringXY(0,1,"Lon:");
_delay_ms(1000);
i=0;
while(longi_value!='\0')
LCDWriteInt(longi_value,1);
i++;
LCDWriteInt(longi_dir,1);
_delay_ms(1000);
void usart_init()
/* Enable receiver and transmitter */
UCSRB = (1<<RXEN)|(1<<TXEN);
/* Set frame format: 8data, 2stop bit */
UCSRC = (1<<URSEL)|(1<<USBS)|(3<<UCSZ0);
//UCSRB |= (1<<RXCIE) | (1 << RXEN) | (1 << TXEN); // Turn on the transmission and reception circuitry
//UCSRC |= (1 << URSEL) | (1 << UCSZ0) | (1 << UCSZ1); // Use 8-bit character sizes
UBRRL = BAUD_PRESCALE; // Load lower 8-bits of the baud rate value into the low byte of the UBRR register
UBRRH = (BAUD_PRESCALE >> 8); // Load upper 8-bits of the baud rate value into the high byte of the UBRR register
while (!(UCSRA & (1 << RXC))); // Do nothing until data have been recieved and is ready to be read from UDR
return(UDR); // return the byte
Here is my code...
#include<avr/io.h>
#include "lcd.c"
void usart_init();
int main(void)
LCDCmd(0xC0);
while(1)
if(value=='$')
if(value=='G')
if(value=='P')
if(value=='G')
if(value=='G')
if(value=='A')
if(value==',')
while(value!=',')
value=lati_value;
while(value!=',')
value=longi_value;
_delay_ms(1);
_delay_ms(1000);
i=0;
i++;
LCDCmd(0xC0);
_delay_ms(1000);
i=0;
i++;
_delay_ms(1000);
void usart_init()
In any case, have you first determined you're getting valid sentences by simply displaying the values piped to a debug window? That should be the first step.
Be sure to wait for the GPS to go into satellite lock. The red LED will stop flashing.
-- Gordon
After the GPS module's red LED stopped blinking only I tried to get the NMEA $GPGGA sentence..
Microcontroller is not able to access any valid information from it..
I think it is not at all receiving '$ also'...
Regarding my code, I will try to give a brief explanation
BAUD_PRESCALE will be having BAUD PRESCALE value and in void usart_init() it will be loaded to UBRR register as
I have Set frame format as 8data, 2stop bit..which is coded in function void usart_init().
My code is based on polling method..
function usart_getch() reads out the data from GPS module
So continuously I will be checking for $GPGGA
while(1)
if(value=='$')
if(value=='G')
if(value=='P')
if(value=='G')
if(value=='G')
if(value=='A')
if(value==',')
like this and saving only Latitude, Latitude direction, Longitude, Longitude direction in arrays lati_value[], lati_dir, longi_value[], longi_dir correspondingly..
Please tel me what is wrong with this..
Thanks..
The docs provided by Parallax are a bit skimpy for this module, but you can look up other SiRFIII modules on the Web, including from the manufacturer, for more details on the serial comm. I cannot find any that say 2 stop bits is supported (docs I have say 0 and 1), so you should be sure you've set up the serial port correctly. Don't make any assumptions here, including whether the data is inverted or non-inverted.
I had asked if you've tried to simply receive the data through a terminal or debug window. Use that technique to make sure you've got the serial communications working. If you get streams of sentences than you're ready to go on to the next piece.
I understand how your program is supposed to work, but it's much better to take these one step at a time.
