UV Ultraviolet - flame detection
![Erlend](https://forums.parallax.com/uploads/userpics/104/nNDYNLYRGY2Y3.jpg)
I need a sensor to detect that a gas burner has been ignited - or that it is still burning. I know that an UV sensor is best suited. IR detector is not so good, since it looks for thermal radiation from surfaces and a flame is not such a good radiator in this respect. I therefore have to find some other use for my IR detector.
My question is: where can I source an UV sensor? It normally is a photodiode with a filter for ordinary light.
Erlend
Erlend
John Abshier
http://jp.hamamatsu.com/products/sensor-etd/pd006
I see there is a company that sells an R2868 with a custom driver board for US$43, and they also list on ebay.
It detects UVC, short wavelengths.
Might just be a phototransistor. I had excellent results using phototransistor sensors at a robot contest to find & extinguish a candle flame many moons ago. My favorite was a Fairchild FPT540A, now rare as hen's teeth.
There is a specsheet for these http://www.dfrobot.com/index.php?route=product/product&path=36_58&product_id=195
http://www.tycosafetyproducts-europe.com/English/Products/Fire/minervadetectors/minervaflamefv300.asp
It's based on the Irisys IR sensor array.
The Hamamatsu UV_TRON works in the region where the interferences have dropped way low in significance. How do robot builders deal with the interference at 940 nm?
Here is a chart from some class notes.
Taken with a spectrometer, the many dips and staircase effect is an instrument artifact, as is falloff at long wavelengths. There are a couple of strong lines around 770 nm. The overall spectrum is largely continuous like a black body, and they attribute that to incandescence of soot particles in the oxygen-starved flame.
The Tyco/Minerva module is very interesting and seems to be available and rebranded into several top-name security systems. The sensor array (256 pixels?) gives good options for contrast detection. That plus a CCTV on the side and its ability to see thru smoke and haze, it could be a great option for a fire-fighting robot. ($$?)
I don't think that the sensor assemblies are available on their own but I'll make some inquiries tomorrow.
I may go on to purchase the vacuum tube based UV detector to experient with, but I don't understand why the IR detector can not do the job.
Erlend
Erland, look at the graphs and you can compare potential levels of background radiation you have to deal with in near IR at 940nm, compared with UVC at 250nm. It is a lot easier to detect a candle in a dark room! The levels of energy are small, so a scheme is needed to detect the contrast between ambient and the fire. One way to enhance the signal is to narrow the beam width and scan back and forth so that the signal becomes AC at a narrow frequency. The MLX90614 is a broadband detector out to 1000s of nm, whereas the other IR detectors discussed have been mostly IR photodiodes, peaking in near infrared at 940nm.
I just had a word with one of my former colleagues. They don't supply the sensor units on their own in small quantities, although I daresay that if someone had a mind-blowing application that would sell lots of units they would provide some free kit. However, their people counters occasionally turn up on Ebay, and I found one for sale in HK:
http://jensenyau.en.ec21.com/offer_detail/Sell_IRISYS_IRC3000_people_counter--8705886.html?gubun=S
It costs £990!
Here are some nice You Tube clips showing it in action:
http://www.youtube.com/watch?feature=endscreen&NR=1&v=j7ufv1w5vrg
http://www.youtube.com/watch?v=KG8r1OqGBWA&feature=endscreen&NR=1
http://www.youtube.com/watch?NR=1&feature=endscreen&v=ExTpFTEjs8M
The tracking algorithm is very effective.
What I have settled for is to order the R2869 detector with an interface board to find out if it is better at detecting the flame. I intend to ignite the gas using an electric ark (auto spark plug) and it could be that it will also detect the arc - all the better, it would mean I will also get feedback about weather that circuit works.
Thanks for all the help, this forum is fantastic!
I surmise the technology could be used to localize anything that can be circled against the background, not just people, fire for example. The group I am working with is measuring exposure to particulates from fire. It may be an open fire, or it may be in one of several different stoves (gas, or enclosed wood fires) which would be evident as heat or flame sources. They would want to know both which fires are being used and how many people are present in the room, and of those people, how many are children.
Is the flame detector the same hardware as the people detector, just different processing?
I haven't a clue about how they do the flame detection, there was a different team working on that. I remember them messing about with sand-filled containers having inflammable liquid poured into them, and being set alight. It took them a few years, I think, as they were still working on it when I left.
