Eddie control board connectors ?
Sorry if this sounds like a stupid question but what are the two motor connectors (the white connectors) called ?
Or where can i find them (from Europe)
Those are standard Molex (brand) connectors, but I won't be able to give you the model number until I get back to the shop in the morning.
-Matt
We haven't had one of those since erco last posted something...
Those connectors are made by Molex. Digikey's part number is WM-1783-ND. From there you can get the mfr's actual part number, the mate to it, and perhaps where to find them in Europe.
Alternatively, you can always cut off the connectors and just hard-wire them into a standard terminal block (that's what I do sometimes).
But that depends on your application...
-Matt
But thanks for the reply anyway.
Don't be a stranger - keep us posted on how your project is going
-Matt
Excellent idea! We should do exactly that...the only problem is that the crimp tool is expensive. However, with reasonable care you should be able to do a reasonable job with a good pair of pliers.
Regardless, I think you're right - we will add them.
I'll check our BOM costs, but maybe we can crimp short (12") leads onto the terminals, like a little pig-tail.
-Matt
Ugh, can you chech the part number for me? These are the much smaller connectors used for the Li-ion Power Pack / Charger.
Better yet can I buy the connectors with tails from you all?
