does anyone knows how to correct error code 2 .. could not fin listen windows(LIW) from the tag.... or what should i do to correct this error...
Where do you get the error and what code are you running? How do you have your parts connected and what have you done so far to fix the error? Have you tried the sample code?
Sorry... i did not explain my question clearly sir....mmmm i am using the new Parallax RFID READ/WRITE MODULE (28440).... and try to interface it with arduino ...but sadly no response from the reader....here is the sample codes that i use from arduino tutorial... the connection are...
5V to VCC
0V to ground
Pin 6 to SIN
Pin 8 to SOUT
here is the sample codes....actually i post it to another thread...and i am trying to perform the write operation....
void suppressAll() //Keeps error code & the "write confirmation" codes from being printed in the serial monitor
if(mySerial.available() > 0)
{ mySerial.read();
suppressAll();
if(mySerial.available() > 0) {
val = mySerial.read();
Serial.print("Debugging stop here");
if (val == ) //If data was written successfully
Serial.println("Writing success!");
else Serial.println("Writing failed...."); //If an error occured during writing, discard all data recieved from the RFID writer
delay(250);
the output of this code is
RFID Write Test
Debugging stop here
Writing failed..
seems the line
is not equal to 1 so it directly jump to the else condition....
if the i try to change the codes from this...
(val==2)
it gives me....and output of
RFID Write Test
Debugging stop here
Writing success...
the mySerial.read() returns the value of 2 which is from the RFID 28440 datasheets is
Value Name Description
0x01 ERR_OK No Errors
0x02 ERR_LIW Could not find a Listen Window (LIW) from the tag
0x03 ERR_NAK Received a No Acknowledge (NAK), possible communication error or invalid command/data
0x04 ERR_NAK_OLDPW Received a No Acknowledge (NAK) sending the current password during the RFID SetPass command, possible incorrect password
0x05 ERR_NAK_NEWPW Received a No Acknowledge (NAK) sending the new password during the RFID SetPass command
0x06 ERR_LIW_NEWPW Could not find a Listen Window (LIW) from the tag after setting the new password during the RFID SetPass command
0x07 ERR_PARITY Parity error when reading data from the tag
can anyone help me to solved this problem.. thanks in advance................................
As you can probably figure out, after posting the same questions three times, the Parallax forum is probably not the correct place to ask this question since it has to do with Arduino software.
It has many examples of using an Adrunio with Parallax products, although the RFID is not one of them, but it does have many examples using a serial interface that might help.
i solve my problem...i go to the store where i bought my rfid reader/writer and exchange it to a new one.. luckily it working... i think the product it self is the problem.....
Your original post is pretty vague. Do you have the Parallax product numbers?
5V to VCC
0V to ground
Pin 6 to SIN
Pin 8 to SOUT
#include <NewSoftSerial.h>
#define RFID_WRITE 0x02
#define txPin 6
#define rxPin 8
#define whichSpace 4
#define first 1
#define second 26
#define third 3
#define fourth 27
NewSoftSerial mySerial(rxPin, txPin);
void setup()
Serial.begin(9600);
Serial.println("RFID Write Test");
mySerial.begin(9600);
pinMode(txPin, OUTPUT);
pinMode(rxPin, INPUT);
{ mySerial.read();
suppressAll();
void loop()
int val;
mySerial.print("!RW");
mySerial.write(RFID_WRITE);
mySerial.write(whichSpace);
mySerial.write(first);
mySerial.write(second);
mySerial.write(third);
mySerial.write(fourth);
delay(250);
RFID Write Test
Debugging stop here
Writing failed..
seems the line
(val==2)
RFID Write Test
Debugging stop here
Writing success...
That said, do check out this link:
https://sites.google.com/site/parallaxinretailstores/home
Jim
