Cable for Digital I/O Board
Does Parallax make a cable that will connect the Board Of Education either serial or USB, to the Digital I/O Board (27113)? Connector on BOE AppMod Header (X1) to the Digital I/O Board (J19). One end will have to be male and the other end female.
Gene
Gene
We do not have such a cable, however you could easily make one using either an old drive cable or the raw parts from Jameco, Digi-Key, Mouser, etc. If you have a 20-conductor ribbon cable with 2x10 F-F connections you can always plug a 2x10 header into one end to make it match up to the BoE connector. The flat ribbon connector to make these can be found here as an example.
