Do I have a corrupted memory block? — Parallax Forums
turbosupraturbosupra Posts: 1,088
edited 2012-02-23 15:50 in Propeller 1
Ok, after 3 hours of banging my head against the desk, I figured out if I used result := @adc1Result, I get the first screen capture, but if I use result := @adc2Result it works as shown in the second screen capture, that is the only change I'm making. Do I have a corrupted memory block on my protoboard? I'm sorry I can't attach the objects, but the work firewall blocks that.
Also, how can I concatenate this line s2.Concatenate(result, string(ch)) ?
  { Have methods
        1. collect adc data, format it, save it to globlal variable
        2. send global variable values in formated type over serial/method also receives serial data and decodes/updates global variables
CON
_clkmode = xtal1 + pll16x
_xinfreq = 5_000_000
  CLK_FREQ = ((_clkmode - xtal1) >> 6) * _xinfreq
  MS_001   = CLK_FREQ / 1_000
con
  #1, HOME, #8, BKSP, TAB, LF, CLREOL, CLRDN, CR, #16, CLS      ' PST formmatting control
con
  RX1 = 31
  TX1 = 30
  SDA = 29
  SCL = 28
  CS  =  7
  CLK =  8
  DIO =  9
VAR
long numerator
long denominator
long constantMultiplier
long additionAnswer
long subtractionAnswer
long multiplicationAnswer
long divisionAnswer
long adc1Result2
long captureAnalogData1Stack[20]
Byte adc1Result[128]
Byte adc2Result[128]
Byte string1value[128]
OBJ
'pst : "Parallax Serial Terminal"
strings : "Strings"
s2 : "Strings2"
f : "Float32"
fm : "FloatMath"
fs : "FloatString"
term: "FullDuplexSerial"
adc  : "jm_mcp3208_ez"
PUB Main
  term.start(RX1, TX1, %0000, 115_200)
  cognew(captureAnalogData1, @captureAnalogData1Stack)
  term.str(string("Starting"))
    term.str(String(13))
  repeat
    waitcnt(clkfreq + cnt)
PUB captureAnalogData1 | t, ch, analog, adcNumber, localIndex, zresult
  adcNumber := 1
  localIndex := 0
  adc.init(CS, CLK, DIO)                                        ' start adc driver
  waitcnt(MS_001 + cnt)                                         ' let objects load
  t := cnt
  repeat
    localIndex := 0
    repeat ch from 0 to 7
      {term.str(string("ch"))
      term.dec(ch)                                              ' display channel #
      term.str(string(": "))
      term.dec(adc.read(ch, adc#SE))                            ' display channel value
      term.tx(CLREOL)
      term.tx(CR)
      term.dec(adcNumber)
      term.str(string("-"))
      term.dec(ch)
      term.str(string(":"))
      term.str(String(13)) }
      adc1Result~
      adc2Result~
      s2.Concatenate(result, string("1"))
      s2.Concatenate(result, string("-"))
      's2.Concatenate(result, string(ch))
      s2.Concatenate(result, string(":"))
      term.str(string("adc2Result is: "))
      term.str(result)
      'result := (adcNumber) + (string("-")) + ch + (string(":")) + (adc.read(ch, adc#SE))
      waitcnt(t += constant(MS_001 * 500))
    waitcnt(t += constant(MS_001 * 500))                        ' update every 100ms
  • turbosupraturbosupra Posts: 1,088
    edited 2012-02-23 14:44
    I can also change the variable portion of the code (see bolded part) to the below and it works correctly as shown in the screen capture below
    VAR
    long numerator
    long denominator
    long additionAnswer
    long divisionAnswer
    long adc1Result2
    [b]Byte placeHolder[128][/b]
    edited 2012-02-23 15:15
    Try making your stack bigger. Twenty longs may be a bit skimpy.
    edited 2012-02-23 15:26
    I answered my own question about the string conversion
    Thanks Phil, that did it! What do you usually set your stacks for?
  • T ChapT Chap Posts: 4,223
    edited 2012-02-23 15:38
    You can always make the placeholder just a single byte, then in your code add a line to display the placeholder value. Init the byte to some value, then if it is getting changed you know that your stack is too small and the next slot is getting used.
    I bet the concatenate method needs the strings to end with zero. The arrays will only be all zeros the first time through the loop.
    adc1Result~
          adc2Result~
    Will only clear the first element of the array.
    You should use:
    bytefill(@adc1Result, 0, 128)
          bytefill(@adc2Result, 0, 128)
    to clear the arrays.
