Alarm System Project
I'm currently working on a alarm system project for my micro controls class. I tweaked the code found in the What's a Microcontroller book to where I can have a LCD and keypad hooked up so the system is stand alone and not using my computer. I got the LCD to work fine with the program, but my problem is the keypad. I'm not sure how to program it in so that what I type on the keypad will be read by the LCD and activate the alarm.
i have that problem to, i always forget useful tidbits of info.
you left out a bit of needed info.
what kind of keypad
what kind of LCD
what way are you using the i am assuming BS2 exactly you said security system but that can mean a lot.
i have a BS2 "watching" my windows for breakage, opening and my door and i use a jump key (a plastic card that jumps connections) not a keypad. all in all i have 14 windows and 3 doors watched and the BS2 will trip a relay connected to 4 high DB sirens and send a siganal to my computer to call my cell phone.
funny thing is the computer i had the basic stamp code on is gone and if the basic stamp breaks i will have to rewrite it
and anyway i will only help i wont give you direct answers cause your doing this for school right?
and i always say "Cheating only sets on up for failure" so if you can post a pic or a rough drawing of your design i will give advice if i can. as is i dont know if your using the old keyscar model or the serial keypad.
And it is for school.
At the moment I have my system in a mock up, which consists of a cereal box with cutouts to display the LCD and the keypad right next to each other and a part of a door. the door has a piece of craft wood that can push down or let go of the switch.
I can post my code later when I venture back to my windows side when I try and see what I'm doing wrong.
