The title said it all. Do anybody knows how to set BS2 to 8 bits, 1 start, 1 stop, no parity? I have not clue.
Hello Luis - I checked the BS programming manual under the SERIN section. There is information on how to set 1-stop bit, 8 data-bits w/no-parity, or 7-data bits w/even-parity.
I see nothing that describes 1-start bit, 1-stop bit, 8-data bits w/no-parity.
I'm sure one of the Basic Stamp wizards will chime in shortly.
Would be nice if you trought some example codes! gracias.
Will just any 8-N-1 baudmode be satisfactory?
If you look in PBASIC Help, under both SERIN and SEROUT, there are tables listing baudmodes for 8-N-1 (8bits, no parity, 1 stop bit) for all of the BS2 variants.
If you need help beyond that then you need to tell me, at minimum, which Stamp you are using and provide a link to the device with which you intend the Stamp to communicate.
SERIN, SEROUT -- baudmode tables
All choices include a start bit.
They really take care of you around here, y'know.
...sigh - as always, you are correct Mr. Allen.
For some reason I failed to remember the start bit.
