PIR Sensor (#555-28027) - The Missing Manual details...
The following information seems to be missing from the specification sheet for this part:
In addition, is it possible to disable the LEDs behind the lens - not really that useful for low-power applications!
Can anyone fill in the blanks?
-Chroma
- Fresnel lens specification (in both horizontal and vertical patterns)
- Fresnel lens manufacturer
- PIR sensor element specification and manufacturer - very difficult to compare against other PIR modules.
-Chroma
Re: nixing the LED. Someone previously posted that there's a trace you can cut which disables the LED. That part seems true enough but I get the sense that cutting that trace also changes the response time of the sensor (doesn't stay on as long). With the lens facing you and the three-pin header facing up, hard to the right of the lens, to the 10 o'clock of the right mounting hole, there's a via with a trace heading under the lens. Cut that trace and the you disable the LED but, like I said, it seems to change the response time. Do at you own risk.
To management: I hope you guys add a "stealth mode" for Rev C.
