Shop
OBEX
P1 Docs
P2 Docs
Learn
Events
parallax rfid 28440 to pic16f877a???? — Parallax Forums
toggle menu
Categories
Discussions
Sign In
Register
Sign In
Register
Categories
Discussions
Sign In
Register
Home
Accessories
axel
1
2012-02-14 23:20
edited 2012-02-17 08:22
in
Accessories
is it possible to connect parallax rfid 28440 to pic16f877a? to write data in tags?
Parallax Engineering
14,406
2012-02-17 08:22
Hello,
Yes, you can connect the RFID Read/Write Module to a PIC via the SIN/SOUT pins, which would connect to the TX/RX pins on your PIC. Based on the example code you should be able to write some code for the PIC to talk to the module. I hope this helps.
Sign In
Register
to comment.
