Remote Control Power
I had a bench power supply which could do 0-24VDC at up to 5A which would run a JK-FlipFlop circuit with two IRL530's to power a hydraulic valve to easily slam the valve open and closed at full pressure or less depending on the voltage selected, resulting in a faster or slower hydraulic actuator motion. Setting the power supply to 12V would run it at about half speed. Now I've been trying to automate that manual setting of the power supply using a Prop output of a PWM signal into a TC4427 to drive a pair of IRF3708's. Unfortunately the result has a large drop-out in response between 12 and 24 volts compared to the manual power supply.
Is my best bet to buy 12V coils which may capture the lower response or try to replace TC4427 with something better? Is the problem that my newer fixed voltage 24V 1A power supply not powerful enough at mid-range? I have seen something about an electronic remote control pot on Digi-key. Would it be best to just try to copy the old bench power supply circuit and replace the manual voltage control pot with an electronic pot? If nobody knows directly, any suggestions for a course of action?
Thank you.
Thank you.
Is this a servo hydraulic valve?
