How can a person possibly argue against that logic?
Okay, so if the Propeller can think, is it possible for the Propeller to have improper thoughts (I will leave this open to imagination). And if so, what would be the best method of punishment for such improper thoughts? Perhaps some light punishment such as Grounding the offensive pins for a couple of weeks, or should it be severe such as erasing the EEPROM? There are important ramifications that must be considered.
No. And neither can a million of them wired together.
Or conversely yes. And so can a flip-flop, or NAND/NOR gate (XOR gates are especially clever) or just a single transistor. Indeed the humble mechanical light switch does a lot of thinking, it remembers to be on when I command it on and remembers to be off when I command it off.
Given those definitions, any micro with a von Neumann architecture can be said to "think," with the exception of #3 insofar as I am not acquainted with the said program. And some Harvard architecture chips -- such as the 8051 family -- can be modified via hardware mods to be von Neumann machines.
While I am not familiar with "Lerner" [sic], didn't the program Eliza "invent" questions?
"Grogg only believe sillycon chip think, when Grogg see sillycon chip push other sillycon chip back to hind teet"...
Grogg makes a good point, it seems very important to all things that "think"
He mentions the very important thing lacking from our "thinking sillycon" chips.
INSTINCT!!!, knowing something even before it is born.. Instinct that drives competition...
Is Grogg right? He seems to think an entity needs to have some instinct and competition pre wired..
Can or will computers ever think? Well this has been a subject of much debate between even the greatest minds... First of all I have would like you to answer a question. What is 4
Well when your teacher stood over you desk in elementary and do drilled you on the multiplication tables was that not programming?
No, it was not. If it were, I would have grasped it the first time, without needing repeated drilling. Fortunately, though, my brain was plastic enough to learn things for which it was not hardwired form birth. Acquiring data and functionality through programming and acquiring knowledge and experience through learning are two entirely different processes.
Well, except if you found it impossible to remember the multiplication tables, up to 12 times 12 in England in my day, you soon learned that you could get thexresults with repeated additions and other better short cuts.
In this way the truth of what was being drilled into you became aparent, it was not just learning, something much deeper.
Bruce
--Rich
Hmm...
-Tommy
Dude, where's your car.
I had an in-line image but the alien website wouldn't let it load, and this forum would not allow me to delete my post, so.... poop it is.
Complete Student Essay at http://onlineessays.com/essays/tech/tech62.php
Hmm.......Existentialism in the haze of a Hash function:)
We don't think either!
OK. Next problem.
