Making PCBs at home
PCBs with tracks as narrow as 8/8 mil (8 mil width with 8 mil spacing) or even less are easy to make at home with inexpensive equipment. I use an HP 9540 printer to print transparencies that are used with positive pre-sensitised PCB material in a simple UV exposure unit. After exposure the board is developed, etched and then drilled.
Printing
I use the HP 5940 printer because it is comparatively cheap, it can deliver 1200 dpi output directly from the Pulsonix PCB software I use, and it works well with the JetStar Premium film available from Mega Electronics (UK).
I print on an ordinary sheet of A4 paper initially, cut a piece of film a bit oversize (it's expensive), and stick it to the A4 printout with a piece of masking tape. The matt surface of the film must be uppermost. It goes into the paper input tray with the film on the underside, and the tape towards the back of the printer, in the feed direction.
Print the artwork using the best quality setting, and cut it to size. I mainly make single-sided boards, the artwork has to be reversed for a through-hole board with the copper on the bottom.
Exposure
Cut the PCB laminate to size and remove the protective black film. I use Mega Electronics FPC 16 material as it's very easy to cut and drill, unlike the more usual FR4.
Place the sensitized side of the laminate in contact with the transparency (ink side against the resist) and put it on the exposure unit. Switch on the lamps and leave it for the required exposure time. This needs to be established beforehand using test strips, as was done with photographic enlargers.
Remove the laminate, and develop it.
Development
I use caustic soda (sodium hydroxide) solution (about two teaspoons to a litre of water), and it takes about 30 seconds to remove the exposed resist with constant agitation in a small plastic container at room temperature. Wear rubber gloves.
Etching
I use warm ferric chloride solution for etching, it lasts a long time and can be used until it is exhausted. It's usually supplied in powder form. Follow the instructions when making up the solution.
Put about 1.5 cm of ferric chloride solution into a suitable plastic container, and place the container in an old washing up bowl with about 2.5 cm of very hot water in it. I use boiling water straight from the kettle. Put the laminate into the ferric chloride and rock the container, wearing rubber gloves. The board should be etched in about 5 minutes.
Remove the board from the solution, rinse thoroughly in clean water, and dry. It's now ready for drilling.
Double-sided boards
Double-sided boards can be made by sticking the top and bottom transparencies together along one edge, ensuring that the two sides are properly registered. The double-sided laminate is then placed between the two transparencies, and each side exposed in turn. With care, reasonable results can be obtained. I prefer to make single-sided boards, with a few wire links on the other side.
UV exposure
Here is a photo of my home-made UV exposure unit:
http://www.leonheller.com/Photos/UV%20unit.jpg
A sheet of ordinary window glass cut to size rests on the wood strips.
It takes 12 minutes to expose the laminate I use.
Removing ferric chloride stains
FeCl3 stains clothes, and anything else, badly. Oxalic acid deals with the stains quite well - make a solution with water and soak the stain. Wash the item. Oxalic acid is available on Ebay, it's used for whitening wood. It's rather toxic, don't drink the solution.
Suppliers
Mega Electronics (UK) supplies JetStar and JetStar Premium film, as well as LaserStar film for laser printers:
http://www.megauk.com/artwork_films.php
I also use their FPC 16 laminate:
http://www.megauk.com/pcb_laminates.php
I actually buy it from ESR, as they don't have a minimum order charge:
http://www.esr.co.uk/
Farnell sells something similar, but I don't find it as good as the material sold by Mega. Farnell also sells the film:
http://uk.farnell.com/jsp/search/browse.jsp;jsessionid=WZBJEPFICXA44CQLCIQZMMQ?N=0&Ntk=gensearch&Ntt=jetstar&Ntx=mode+matchallpartial&suggestions=false&ref=globalsearch&_requestid=453190
Please ask if anything needs clarification.
Printing
Exposure
Development
Etching
Double-sided boards
UV exposure
Suppliers
My concern about disposing of the waste chemicals has kept me from making PCBs at home.
BTW, it's now very difficult to purchase NaOH(in USA). They used to sell it in the grocery store, now I have to by it off eBay.
The solution can be regenerated with hydrochloric acid and hydrogen peroxide, or by bubbling air through it, and will gradually become cupric chloride, which is a good etchant in its own right.
Developer which doesn't contain NaOH can be bought, but it's expensive.
A google search shows that is not far fetched.
http://www.extremetech.com/extreme/106599-first-inkjet-printed-graphene-computer-circuit-is-transparent-flexible
I'm talking about printing the “copper trace” itself, actually graphene that is electrically superior to copper.
I try to drill before I etch if possible.
Bean
@Leon, some links to known good products could be useful.
I suspect that roughed up laser transparencies would work.
Bean,
I use tungsten carbide drills, running at 15,000 rpm, and don't have any problems with pads coming off, even with small annular rings. I often use teardrops for added support.
http://webspace.webring.com/people/jl/leon_heller/msp430.html
It was made a long time ago, using a laser printer and tracing paper.
http://physics.aps.org/articles/v5/24
http://hardware.slashdot.org/story/11/11/26/0439205/uk-university-creates-first-inkjet-printed-graphene-circuit
Has anyone tried this sort of UV exposure box, using LEDs ?
http://s.eeweb.com/members/circuit_projects/blog/2012/01/26/ultraviolet-exposure-box-using-LED-1327597271.jpg
or this
http://www.electronics-lab.com/projects/mcu/018/index.html
and I see Mouser has UV LEDs at tolerable prices ?
VAOL-5GUV0T4 405nm 160mcd 30deg 100: $0.438
( 2,910 In Stock)
VAOL-5GUV8T4 385nm 80mcd 30deg 100: $0.571
( 2,579 In Stock)
- draw a board scheme on a paper with pen
- wrap a board with this paper and drill holes
- get a waterproof lacquer and a pen (old kind of pen used to write with ink on drawing paper in these times) and draw lines on board with this pen
- treat a board with FeCL3
- use a solvent, then a home cleaning detergent to clean PCB
- ready
FeCl was hard to get (Poland, 198x) so I experimented with solutions made from h2o2, vinegar and salt, it worked
I made my PCBs the same way when I started playing about with electronics at home. I used to paint the tracks with cellulose paint and a fine paintbrush.
Joe,
A darkroom isn't required for photo-etch.
I have seen examples of people using simple CAM machines using stepper motors and a dremel. I've thought about one of these quite often, but do nowhere near the volume necessary to justify the price of one. Could be built DIY IMO.
http://youtu.be/gZFvra3kXEs
I need to remove the resist and drill the board. I'll see if I can get a better photo when I've removed the resist.
The problem with these DIP offshoots, is they do not cover the newest variants, so the LPC11A14 / LPC11U14 for example, are not showing anything even planned in DIP.
Also, being wide body, they really have chosen just the hobbyist niche; a SDIP might have more volume but perhaps the die just will not fit ? Lack of wide-supply is another drawback in NXP devices.
I can also see part codes for DIP24, but no road map mention of these, so do we guess they are pruned for the DIP28 ?
Not such good news for someone who designed-in a DIP24 ?
I also asked for some of the SOIC and SSOP ones, but they are having some problems with them.
