Replace battery with USB on proto board
Why am I paying for 9V batteries ? Looks like I could patch the 5V USB power to the 9V connector + and no more battteries? I would need a jumper across the LM2940 regulator too. The only down side I see is the 5V is now regulated by my PC, might not be as clean and noise free as using the regulator approach. Also would not want to connect any power hungry devices like a servo, because my PC would not provide that much current.
Has anyone tried it ?
In addition, the USB 5v can't go the VIN of the board because there is a 5v LDO linear regulator, which requires something like 6v of input to operate correctly. So, you'll need to somehow get around that. My solution is to remove the 5v regulator entirely, and then the USB 5v line could be used. Note that you shouldn't have both the 5v regulator and the 5v line both trying to drive (or attached to) the 5v rail.
ps: I too don't know why you're paying for batteries. Just use a wall power supply...
Which board specifically do you have? The HomeWork Board or the Board of Education, or some other board?
If you have the homework board, it looks like the bypass option will work just fine. There is only the one regulator on the board, so it should be fine just to disconnect it and put the USB 5v in it's place.
If it's a BS2 on a BOE, then it looks like it's still possible, just a bit more difficult. The BS2 has a regulator onboard that could be routed around, the only difficulty being it's small size. The principle is the same, however.
As I mentioned in my earlier post this would require rewiring the Basic Stamp chip to remove power from Vin and switch it to VDD.
I would not recommend this modification for average users... The other suggestion of a wall wort supply is better for most users.
thanks
Randy
