HMC5883L Compass Module
I just purchased the HMC5883L and downloaded the HMC5883L_demo.bs2. I get an error for the I2CIN and I2COUT commands. The error is (Label is missing ':'). When I look in the PBasic syntax guide it only shows the 2P,2PE and 2PX. Can I interface with the device using my BS2 or can you only use the 2P,2PE or 2PX?
http://sites.google.com/site/parallaxinretailstores/home/compass-module-3-axis-hmc5883l
Jeff T.
i'm trying to read the data from hmc 5883l using AT89s52 controller. what is the minimum oscillator frequency which i need to read the data properly??
I don't understand how the oscillator frequency has anything to do with the HMC5883L?
The sensor has a maximum I2C clock frequency of 400kHz but there isn't a minimum frequency listed. It can be read as slow as you want.
