New Prop Motor Driver Board — Parallax Forums
T ChapT Chap Posts: 4,260
edited 2012-02-19 10:36 in Propeller 1
Here is something I built recently. It is designed for my dual purpose CNC/Pick and Place machine. The Pic and Place uses the Prop as the step and direction generation, with USB input from a PC based app. The CNC runs off a parallel port, Mach3. A SPDT toggles each of 4 motors between USB and Parallel control. There are 4 mosfets for controlling vacuum, tape advance, spindle (via solid state relay), etc.
Anyways, you might notice that this board is using the new invisible Prop.
640 x 478 - 109K
  • JLockeJLocke Posts: 354
    edited 2012-02-07 22:55
    Is that a Prop II installed on your board?
  • T ChapT Chap Posts: 4,260
    edited 2012-02-08 06:42
    No, regular prop was there, but it got robbed.
  • idbruceidbruce Posts: 6,197
    edited 2012-02-08 15:23
    When you put a Propeller chip in the midst of a housing project, you should expect that sort of thing :)
    Very nice looking board, but WOW those connectors sure are tall. Are they a special type of connector?
    edited 2012-02-08 20:33
    Not really that tall, I think it is an optical illusion. Phoenix type.
    edited 2012-02-13 03:36
    T Chap wrote: »
    Thought maybe it was a Prop II since I couldn't see it! :lol:
  • tonyp12tonyp12 Posts: 1,951
    edited 2012-02-19 08:26
    Today I will place an order from Itead for my Quad Stepper Board for the Quickstart.
    Can be mounted above or below the board (or with wires used with any board)
    4 steppers or 8 bi-directional brushed motors. (2 Amp peak each winding)
    Current control with 0.1 to 1ohm Resistors.
    12bit ADC 4channels.
    Video out.
    I will created a new post when this item will be available for sale (about 3weeks)
    846 x 561 - 120K
  • AribaAriba Posts: 2,697
    Cool
    Why not add a dual N-FET to control the heating elements of a 3D printer, and some digital inputs with pullups for limiting-switches? Then a Quickstart and this board is all you need to drive such a 3D printer.
    What driver chips do you use?
    Andy
