Position sensing using ultrasonic sensors
There are many transmit/receive ultrasonic sensor pairs like Ping.
I want to create a perimeter network of ultrasonic transmitters with one receiver within the perimeter.
The position of the receiver would be calculated by trigonometry knowing the distance from each transmitter.
Does anyone know of discrete transmitter and receiver ultrasonic modules?
But, as Mike stated, there is that pesky directionality issue.
Mike, the perimeter stations and the target will be connected. Each perimeter station will be fired after some delay in an endless loop. The target will get a distance from each perimeter station.
I will start experimenting and keep you informed.
- 'beak
I think you've missed the point of my idea completely. Firing the stations autonomously in a loop will not work with the Ping))). The robot has to trigger each transponder itself (using unique IR codes), so that its Ping))) can start its timing sequence. The transponders are not, and do not need to be, connected to each other.
2) I have implemented a one-transmitter, two-receiver positional network using blanked pings and found it to be very stable and accurate.
3) The advantage of using the ping like this is that you do not need to make your own transmitters and receivers (I cannot find any individual modules for sale).
4) It is thus possible to build a position sensing scheme using blanked pings. There is a very good article on the trigonometry mathematics of positional schemes by Larrt Foltzer in the Mar2012 Circuit Cellar.
5) I attach a photo and program for information.
6) Now, my real interst is locating the position of my pool cleaner in my pool. I cannot locate cheap underwater transmitters or receivers - can anyone help?
http://www.futurlec.com/Ultrasonic_Sensors.shtml#TR40-16OA00 have sensor modules.
