Q. about builtin functions with different memory models — Parallax Forums
ReinhardReinhard Posts: 489
edited 2012-02-07 05:07 in Propeller 1
I have this code snippet:
void main()
 int a = 0xAAAA;
 int c = __clzsi2(a);
if I gcc this way
propeller-elf-gcc -mlmm  -o main.elf  main.c
it compiles without problems
if I take this way
propeller-elf-gcc -mcog  -o main.elf  main.c
this errors occurs
c:/propgcc/bin/../lib/gcc/propeller-elf/4.6.1\libgcc.a(_clzsi2.o): In function `
__clzsi2':
c:\src\build\gcc\propeller-elf\libgcc/../../../../propgcc/gcc/libgcc/../gcc/libgcc2.c:706: undefined reference to `__LMM_MVI_r7'
c:\src\build\gcc\propeller-elf\libgcc/../../../../propgcc/gcc/libgcc/../gcc/libgcc2.c:706: undefined reference to `pc'
c:\src\build\gcc\propeller-elf\libgcc/../../../../propgcc/gcc/libgcc/../gcc/libgcc2.c:709: undefined reference to `pc'
c:\src\build\gcc\propeller-elf\libgcc/../../../../propgcc/gcc/libgcc/../gcc/libgcc2.c:709: undefined reference to `__LMM_MVI_r7'
c:\src\build\gcc\propeller-elf\libgcc/../../../../propgcc/gcc/libgcc/../gcc/libgcc2.c:709: undefined reference to `__LMM_MVI_r6'
c:\src\build\gcc\propeller-elf\libgcc/../../../../propgcc/gcc/libgcc/../gcc/libcc2.c:709: undefined reference to `pc'
collect2: ld returned 1 exit status
what do I wrong ?
  • ersmithersmith Posts: 6,279
    Reinhard wrote: »
    void main()
     int a = 0xAAAA;
    It's better to use "__builtin_clz" instead of "__clzsi2". This will result in better performance in LMM mode (it will use the "count leading zeros" built in to the kernel instead of calling to the external __clzsi2 function) and it will work in COG mode, where there is no __clzsi2 function available.
    (And on processors like the ARM with that instruction built in, __builtin_clz will expand to the instruction instead of to a function call).
    Eric
