Prop Comms Prob — Parallax Forums
Prop Comms Prob
John BoardJohn Board Posts: 371
edited 2012-02-07 22:57 in Propeller 1
Hi All,
I have been having a small comms problem while programming my props, I am using a demo board and the gadget gangster board. It is fine while loading small programs, but it says "Port # has lost contact" or something like that, it gets up to verfiying ram.
Thanks in advance
  • MagIO2MagIO2 Posts: 2,243
    edited 2012-02-06 23:13
    I also had a problem loading full length programs to the prop. I did not investigate further because my own programs always fit so far. (The one which failed was a demo)
    But currently I am writing a terminal program and found out that it did not receive the text send from the propeller in a continuous stream. Propably it's the same thing in the other direction! As far as I remember timing is very important for the boot-loader.
    Assuming that we talk about a windows box and a USB to Serial interface, you can go to the Device Manager -> your virtual COM-Port. Somewhere you will find a button which opens a window that allows to change some buffer settings. I decreased the buffer values and now the stream looks like being continuous. Maybe now I should also try this demo again ;o)
    Sorry for being so vague, but I don't have my Netbook here to check in detail.
    edited 2012-02-07 08:23
    John,
    Are you using one of the retractable USB cables? If so, switch it for a better cable.
    Even if your cable isn't retractable, you might try switching it.
  • RaymanRayman Posts: 16,456
    edited 2012-02-07 08:30
    Make sure you have the latest version of Prop tool too (V.1.3) Older versions would sometimes have that issue...
  • John BoardJohn Board Posts: 371
    edited 2012-02-07 17:39
    Thanks for all your responses, I will try all.
    Ohh, I am running Prop tool v1.2.5, so I am upgrading now :)
    Thanks again,
    John
    I've upgraded to 1.3 and all seems to be going fine! Thanks!
