Linking XBee to Altimeter
Ok I've been working on a project for a rocket that I am helping design for my senior design class at Texas A&M and was directed here to ask a question about the XBee unit I am planning on using. I will be using a pair of XBee PRO 60mW Wire Antenna units to do an active downlink from my rockets altimeter to a computer at our launch site. The unit that is onboard the rocket was recommended to be attached to a XBee SIP Adapter and then attached to my Stratologger altimeter. My question is, how would the XBee and the adaptor be powered and would the regulator be able to handle a mostly continuous stream of data being transmitter by the atimeter and XBee. The coresponding items are linked below
XBee
https://www.parallax.com/desktopmodules/catalookstore/ProductDetails.aspx?ProductID=641
SIP Adaptor
https://www.parallax.com/desktopmodules/catalookstore/ProductDetails.aspx?ProductID=691
Thanks for the help.
XBee
SIP Adaptor
So in short, your solution seems viable to me.
The SIP adapter includes logic translaters which aren't required for the altimeter (it's 3.3V).
I think a simple XBee adapter with some sort of regulated power supply (3.3V) would be a better solution (and less expensive). I don't know if the level shifter (on the SIP adaptor) will mess things up with a 3.3V device.
You want to be careful about switching regulators. They can cause a lot of radio interference.
Edit: Here are some caps to go with the voltage regulator.
https://www.parallax.com/StoreSearchResults/tabid/768/txtSearch/capacitor/List/0/SortField/4/ProductID/160/Default.aspx
https://www.parallax.com/StoreSearchResults/tabid/768/txtSearch/capacitor/List/0/SortField/4/ProductID/165/Default.aspx
