5 VDC Sensor Input from Vdd?
Do I need to configure a regulated 5 VDC voltage supply, or can I simply use the Basic Stamp 2 Vdd 5V to run a sensor that requires a 5 VDC input with a typical input current of 3 mA? The only thing else being used on the Vdd 5V line is a Tach switch that connects to the VDD which is used when the sensor is turned on. The tach switch is used to store a sensor data point. The sensor accuracy is .25% of span, the output is proportional to the input voltage.
