4-Directional Tilt Sensor and Angle Measurement
Hi group- I have an 8ft TVRO dish that I need to measure the angle of so I can set the dish to a precise elevation angle. Will the 4-Directional Tilt Sensor and a STAMP micro provide 1/2 degree resolution? Has anyone used the 4-Directional Tilt Sensor in a anglular measurement project?
Dave
Dave
Hi Dave,
The tilt sensor documents say this:
....The 4-Directional Tilt Sensor is a perfect accelerometer replacement in those applications which may not need precise angular feedback....
...New locations are triggered when the sensor is rotated roughly 30° toward the new position...
So I'm just guessing that you won't be able to get the kind of precision you need from this. It's probably too coarse. On the other hand, perhaps normal accelerometers could work and perhaps(???) you would need a compass module, too, in order to get the orientation.
I did not see this.
Case closed. Accel needed.
Thanks.
Dave
