Newbie has great success right out of the gate, but I have a question
I have been workingon learning C and remembered the GCC project for the propeller. I downloaded the alpha release this morningand before lunch had time to install it. I compiled the two samples in README_WINDOWS by using Notepad, propeller-elf-gccand then propeller-load. Everything workedjust fine. Had to change DIRA to matchthe Quick Start board and it sets and blinks all the LEDs beside me as I type. Although I have worked with PICs, BS2 andPropeller for some time I am a newbie when it comes to using C and the GCC toolchain (hope thats the correct way to refer to it). I hope to be able to contribute to thisproject with suggestions and insight from said newbie.
Now for thequestion, I noticed in the example for blinking LEDs that keywords like DIRA,OUTA, waitcnt, and CLKFREQ function the same as in Spin accept they are used inC syntax. Is there a document or howwould I go about learning all the available keywords to use with the Propellerlibrary? Example, if I wanted to learnhow to use waitcnt in Spin, I would look in the Spin Language Reference. So my question in other words, how would I dothis for using propeller-gcc?
Thanks forthe help,
Tony
Thanks forthe help,
Tony
Short answer: To find out what facilities PropGCC has to support the Propeller, look at the header files propeller-elf\include\propeller.h and propeller-elf\include\propeller.h in your propgcc directory. Also, and search for "propeller" in the gcc.pdf file that you can download from http://code.google.com/p/propgcc/downloads/list .
To understand how to use the Propeller-specific functions you find, just cross-reference the names to those found in the standard Propeller Manual ( http://www.parallax.com/Portals/0/Downloads/docs/prod/prop/Web-PropellerManual-v1.2.pdf ).
To understand other details of the Propeller PropGCC environment, check out the documents at http://code.google.com/p/propgcc/w/list and http://propgcc.googlecode.com/hg/doc/ .
Currently it's sometimes a bit like being on the frontier - you have to either know what you're doing or stumble around for a while until you find your bearings.
Longer answer, from my perspective:
I personally haven't seen anything like a complete, integrated "Using C (or C++) with Propeller" reference or tutorial. However, I'm not sure that typically exists for C/C++ on any platform or in any microcomputer environment. You typically find general documentation on the C/C++ language and then additional documentation on the special features of a particular environment (i.e. how to run the compiler/linker, any platform-specific libraries, headers, special built-in functions, etc.). Check out the documentation for a previous C compiler for the Propeller: https://www.imagecraft.com/help/iccprop/wwhelp/wwhimpl/js/html/wwhelp.htm ; it's more complete than currently exists for PropGCC, but nowhere near as complete and comprehensive as the Propeller Manual.
The Propeller Manual really serves two purposes:
(1) It documents the Propeller hardware architecture.
(2) It also documents the Spin language (including on how to compile and load programs); it's really a very complete document.
As for using the C or C++ languages: these are standard languages, and you typically don't see the same bundle of "here's how to use the language", and "here's how to use the environment". To learn the languages, if you're running Linux, the compilers are almost assuredly already on your machine. If you use Windows/Mac, you can find free compilers. If you don't know the languages, then pick up a book or use an online tutorial to learn them and play around on your desktop system until you're comfortable (use your desktop because the debugging environment will be so much easier and complete).
Personally, I've known C since the old days so that wasn't an issue for me. But the first programs I ever wrote for the Propeller were all in C (ICC V7 C at the time). Every program I've ever written for the Propeller has been in either C or PASM. So it is possible to jump directly in with PropGCC without starting at Spin.
However, I figured out at the time that the way one uses the Propeller's unique facilities (e.g. cogs, registers (including I/O, clocks, the counters, etc.), wait instructions, etc.) is the same no matter which language you use (Spin, Propeller Assembler, Basic, C, C++, etc.).
So the way I personally grokked this information was to read the Propeller Manual and I also looked at the Spin demo programs. When I picked up PropGCC specifically, I looked at the demo programs ( download from http://code.google.com/p/propgcc/downloads/list ). And I also looked at the above-mentioned header files and documentation.
at time I can approve different ways :
1. Have a look into propgcc\propeller-elf\include\ propeller.h
This is the propeller specific header file.
2. Have a look to the wiki: http://code.google.com/p/propgcc/w/list
3. See the demos.
Hope this is useful for you.
best regards
Reinhard
edit: I forget, of course use this forum for further questions
Tony
Welcome to the test forum. Indeed your questions will benefit us all.
There are also other resources for understanding programming with GCC.
A very good on-line book is: http://publications.gbdirect.co.uk/c_book/
A simple reference for the standard library is:
http://www.utas.edu.au/infosys/info/documentation/C/CStdLib.html
Many library reference manual pages are available on the net.
If you are unsure of a library function usage, you can google it.
For example enter: man 3 printf
From the results you will see urls like this:
man page printf section 3 and
printf(3): formatted output conversion - Linux man page
"man" is the unix/linux manual command and section 3 is for the library.
It may not be immediately clear why these links will help, but as you go through
the tutorials that have been mentioned elsewhere you'll understand.
Additionally we are working on some propeller libraries that will make things easier for everyone.
Hope this helps you and others.
--Steve
I started reading through the Toggle Tutorials and it stated "The default memory model is LMM" so, this is true if no other model is chosen and you didn't use assembler(-mcog), correct?
Tony
As you noted, the only way to get a COG program is to say propeller-elf-gcc -mcog hello.c. Flags -mxmm and -mxmmc are used to build programs that run from external memory; for example, propeller-elf-gcc -mxmmc hello.c will make a program that can be run from EEPROM, Flash, or SDcard.
Tony
Below is the SpinStamp Spin Code I would use if in Spin, the command line I used and the code.
Tony
_clkmode = xtal1 + pll8x ' Enabled External Crystal and PLL X8
_xinfreq = 10_000_000 ' External Crystal Frequency
propeller-load -p com4 blinkss.elf -r -Dclkfreq=10000000 -Dclkmode=XTAL1+PLL8X
Tony, the -Dclkfreq is the Propeller clock frequency and not the crystal frequency.
Your example should work with this (same as -Dclkfreq=80000000):
propeller-load -p com4 blinkss.elf -r -Dclkmode=XTAL1+PLL8X
We are adding -b spinstamp by request, so in the future you can say:
propeller-load -p com4 blinkss.elf -r -b spinstamp
Hope this helps,
--Steve
Tony
I look forward to answering questions. Some are easier than others. I would rather have a bunch of both types of questions now than later.
You're doing fine. Thanks.
--Steve
