Bad resistors?
I recently purchased the propeller 40 pin dip pe platform, i have assembled it and am doing the labs. in one i thought i had a bad i/o pin or something because an LED wasn't going high when it should. but i took the resistor out and replaced it with another and the circuit worked. i tested the resistor with an ohm meter and it didn't even register. is it possible that it was just defective? does that happen often? i KNOW that i didn't put it in any other circuit before, it wasn't even bent yet.
Duane J
47's are always the worst.
This is hilarious!!!
To everyone else, after this ordeal, i tested the same circuit with other 100 ohm resistors and they all worked. just wanted to find any other bad resistors.
