Newbie electrical engineer here, wondering how this buttons panel works. Which wires corresponds to which buttons you can see the circuit printed on the board there but I can't seem to figure it out.
To add to what Leon said, I'd connect the common pin to ground and the other pins to Prop I/O pins (assuming a Prop as a uC). With the exception of the common pin, use pull-up resistors (10K) on the pins. This way the I/O pin sees a high value on the pin except when the button is pressed.
SparkFun sells a wearable keypad that has similar (but a bit more complicated) layout. I made an object to use SparkFun's wearable keypad with a Propeller. There should be a link to it in post #2 of my index.
It looks like you have the common wire connected to ground. Good.
Each of the other wires should have a wire to connect them with a BS pin. It looks like your connecting through a resistor now. You don't want the resistor for this connection, just a wire.
The resistors should connect to were the grey and black wires share a row on the breadboard. The other end of the resistors should be connected with 5V.
Lets see if this schematic displays correctly.
It looks like it worked.
The BS pin will normally be high. Pressing the button will bring it low (since the common wire is connected to ground (without a resistor)).
I noticed the link in your signature takes me to a blank page.
I was able to find your designs after looking a bit here:
http://www.shapeways.com/hisdesign?user_id=104937&ug104937%5Brows%5D=10
You might want to fix your signature link.
