Streaming Output Help
I have searched around on the forum and googled it, but I cannot seem to find much information on the streaming of propscope data to a file(s). Primarily, I would like to stream data to a csv file and then post process the data. But on occassion I would also like to have multiple jpegs saved with time stamps. The main questions I have are, when you go into the 'Stream' menu you get an option for triggering this event every 'X' seconds. How fast can I set that event to trigger? What is the relationship between the time selected on the data capture and the time-divison on the propscope? What is the format for the input, do you use 0.001 or 1m for 1 millisecond (just as an example). How about the output, what is included in the csv contents, can you modify what is included? I just would like some more information on the use of the streaming, any tips, or suggestions.
Thanks.
Thanks.
Thanks.
