Connection pc obligatoire?
Bonjour,
Tout d'abord, veuiller me pardonner mais je ne parle pas l'anglais.
Je suis en r
Je suis en r
First of all, please forgive me but I do not speak English.
I am conducting a class A amplifier
The power this with a soft start and a temperature monitoring.
The program works the way I want ... when the stamp is connected to the pc.
Can you tell me if I did something wrong?
Ampli_board_2.bsx
Thank you in advance!
PS: You can answer in English ...
Ted
What are you working with, a USB BoE, a serial BoE, or...?
Speculating -- it may be that you are missing a ground (common) that the Stamp picks up when connected to the PC.
Perhaps you could sketch out your set-up on a sheet of paper, take a picture of that, and post it.
I use a USB serial converter parallax
Attached is the wiring diagram
http://pvellvehi.free.fr/Presentation/Sboard1a.JPG
Thank you for your answer
From Stamp 'physical' pin 4 (Vss) to pin 24 = ____V?
From Stamp 'physical' pin 4 (Vss) to pin 21 = ____V?
Is all of that on one circuit board or is it on a bunch of breadboards and so on?
[I think you're losing a ground connection when you disconnect it from the PC.]
If you can make all of that then you should be able to troubleshoot it.
There's nothing to prevent the Stamp from running but absence of power (5V).
From Stamp 'physical' pin 4 (Vss) to pin 24 = 5 V
From Stamp 'physical' pin 4 (Vss) to pin 21 = 5 V[/QUOTE]
Obviously make sure it works ... uh ....
I do not understand ...
Well I'll try that way.
Anyway, thank you very much for your answers
With regard to my post / #5:
Is there 5V for the Stamp at the Stamp?
Not measured from some presumed "ground", but right on its pins.
sorry for the schema, I did not notice ...
http://pvellvehi.free.fr/Presentation/Sboard1b.JPG
You put me doubt, whether I have a measure in the right place ... I re-measurement tonight!
The output of your 7805 (+5V), U4, is going to the Stamp's "V_in" pin#24. It (5V) should go to the Stamp's pin#21.
5V isn't enough for V_in, that should be in the range of +8 to 12V.
