Reading Button Inputs — Parallax Forums
John BoardJohn Board Posts: 371
edited 2012-01-31 17:09 in Propeller 1
Hi Y'all,
What is THE EASIEST way to get the input from a button, I have heard you can get the input without even needing an RCDecay circut.
Cheers,
P.S. If you don't reply because you think this question is stupid, feel free to do so
John
  • Mike GMike G Posts: 2,702
    edited 2012-01-30 20:52
    John, see the INA register in the Propeller manual. Also see page 32 in the Propeller Education Kit. Both resource can be found in the Propeller Tool Help dropdown menu..
    edited 2012-01-30 21:02
    John Board wrote: »
    Hi Y'all,
    Cheers,
    John
    Very few questions are stupid. Some need a bit more research than others. Use "parallax button debounce" for google keywords. Lots of history to be sure. Have fun (most important or why bother) and ask away. Lotsa high end talent out here.
    Frank
  • JonnyMacJonnyMac Posts: 9,236
    edited 2012-01-30 21:04
    If you mean debounce an input, here's a simple method that I use. If the pin is pressed and remains pressed for the specified duration (passed in ms), the method will return true.
    pub debounce(pin, ms) : scans
      dira[pin] := 0                                                ' force to input
      repeat ms
        waitcnt(cnt + clkfreq / 1000)                               ' wait 1ms
        scans += ina[pin]                                           ' scan pin
      return (scans == ms)                                          ' return true if good input
  • John BoardJohn Board Posts: 371
    edited 2012-01-30 21:15
    Mike G wrote: »
    Do know the basics of SPIN. I am wanting to find a better way of getting button inputs.
    JonnyMac wrote: »
      repeat ms
    Does this work without any extra circutry?
    edited 2012-01-30 21:22
    Okay, I'll tell you what I'm trying to do: I'm trying to hook up a 3x4 keypad with as little or no circutry as possible.
    So, when responding, if you could not only give me a code example, but some schematics too.
  • cavelambcavelamb Posts: 720
    edited 2012-01-30 21:59
    Sorry about not having code and schematic on hand, but...
    Start with a single button.
    Wire a pull up resistor (10k to 3.3V) to the Normally Open pin of the switch, and ground the Common.
    Reading the button will normally return a 1.
    When the button is pressed, the pull-up is grounded and reads zero.
    So the logic is backwards -
    1 means the button NOT pressed.
    0 means the button IS pressed.
    But then time frames become an issue.
    What happens in human time is not the same as what happens in processor time.
    In human time the switch closes and that's all there is.
    In processor time, the contacts of the switch "bounce", closing and opening again several times.
    Hence the "debounce" requirement.
    In my first little ditty, I debounced my button input -- with an LED.
    :) But then I was only concerned with human time perception - not the processors.
    At least for this effort.
    And the LED blink was on for a Long long LONG long time (in processor years anyway).
    By the time that had finished (waitCnt of 1_000_000) the switch had long since settled down.
    A keypad is a bit more complex.
    Here is a make believe of the process - in positive logic. (Won't work in the real world)
    The switches are wired as columns and rows.
    The columns are wired to output ports so that one column at a time can be scanned.
    The ROWS are wired back to input ports.
    The pad is wired so that that column bit is presented to the entire column of buttons.
    If one of the buttons is pressed, then that key returns the scan bit to one (and only one) of the input ports
    Assume we have a 4 x 4 pad - 4 rows and 4 columns.
    Each column is attached to an output port, and each row and input port.
    Furthermore, assume we have pressed the top left button corresponding to column 4 row 1.
    We scan the columns, one at a time, but putting a 1 (logic hi) on that column and reading
    the 4 input ports (rows) to see if the 1 shows up.
    Nothing happens until column 4, which is returned to input port for row 1.
    At that point we MAY have a valid button pressed.
    MAY, because there may be other buttons pressed also, and we need to eliminate that possibility
    before we can be sure. So we scan the rest of the rows to see if any other key is pressed.
    Only when we are finished with the entire scan can we know for sure if a single valid key is pressed.
    If that seems to make any sense you are well on your way to understanding why nobody can answer
    your question. It depends on the keypad and how it is wired internally.
    Also, hardware is usually rin in inverted logic since it's easier that way.
    The rows could be pulled up with a simple pull-up resistor (way back at the top of this speil) and a
    logic low (0) used for the scan. Then you are looking for the logic 0 to be returned to the input bits.
    After all of that - and it sounds pretty negative, I must admit - there is still hope.
    If you bought your keypad from Parallax, there is probably an example driver for it.
    If it's frome a Blackberry, probably not (but there outta be!)
    So, what kind of keypad are we talking about here?
    edited 2012-01-30 22:05
    One from Jaycar Australia :blank:
    [EDIT] Thank goodness that I'm getting a new 4x4 one today from jaycar, it will work with the example code that I got for a 4x4 keypad.
    edited 2012-01-30 22:18
    Here is some simplistic code that I wrote a few minutes ago:
    CON
      _clkmode = xtal1 + pll16x
      _xinfreq = 5_000_000
    PUB Main
    dira[3]~~
    dira[2]~
    dira[18]~~
    outa[3]~~
    outa[18] := INA[2]
    The pin 18 is an LED pin on the Demo Board, Pin 2 is the receiving pin, and pin 3 is the "transmitting" pin.
    edited 2012-01-30 22:33
    Oh, ok. I'll embarrass myself in front of these guys...
    Here is mine...
    {{ Jan 30, 2011
    Blinky51.spin
    CON
    _CLKMODE=XTAL1+PLL2X
    _XINFREQ =5_000_000
    HI = 1
    LO = 0
    SlowWait = 5_000_000
    FastWait = 1_000_000
    PinOut = 07                     ' has an LED
    PinIn = 06                      ' has a switch wit a 10K pull up resistor
    PUB  MAIN
    dira [PinOut] := 1              'output bit for LED
    outa [PinOut] := 0
    dira [PinIn] := 0               'input bit for button
    repeat
      if ina[PinIn] == 1            ' if button IS NOT pressed
           repeat 1                   'blink it fast
              outa[PinOut] := HI
              waitCNT (FastWait+cnt)
              outa[PinOut] := LO
      else                          ' button IS pressed
           repeat 2                   'blink it slow
              outa[PinOut] := HI
              waitCNT (SlowWait+cnt)
              outa[PinOut] := LO
  • CircuitsoftCircuitsoft Posts: 1,166
    edited 2012-01-30 22:51
    Looks fine to me. BTW, just surround your code with:
    [ CODE] My code [ /CODE]
    but without the spaces.
    edited 2012-01-30 23:18
    Cool!
    Thank you, that helps a lot.
    edited 2012-01-31 00:18
    John,
    As cavelamb has said, a 4x4 keypad is not the same thing as 16 buttons.
    Here's the comments from Beau's keypad object found in the Propeller Tool's library folder.
    * 4x4 Keypad Reader           v1.0      *
    * Author: Beau Schwabe                  *
    * Copyright (c) 2007 Parallax           *
    * See end of file for terms of use.     *
    Operation:
    This object uses a capacitive PIN approach to reading the keypad.
    To do so, ALL pins are made LOW and an OUTPUT to "discharge" the
    I/O pins.  Then, ALL pins are set to an INPUT state.  At this point,
    only one pin is made HIGH and an OUTPUT at a time.  If the "switch"
    is closed, then a HIGH will be read on the input, otherwise a LOW
    will be returned.
    The keypad decoding routine only requires two subroutines and returns
    the entire 4x4 keypad matrix into a single WORD variable indicating
    which buttons are pressed.  Multiple button presses are allowed with
    the understanding that“BOX entries can be confused. An example of a
    BOX entry... 1,2,4,5 or 1,4,3,6 or 4,6,*,#  etc. where any 3 of the 4
    buttons pressed will evaluate the non pressed button as being pressed,
    even when they are not.  There is no danger of any physical or
    electrical damage, that s just the way this sensing method happens to
    work.
    Schematic:
    No resistors, No capacitors.  The connections are directly from the
    keypad to the I/O's.  I literally plugged mine right into the demo
    board RevC.
    Looking at the Back of the 4x4 keypad...
           P7         P0
    │     oo ││││││││ o      │
    │  O    O    O    O    O │
    │  O    O    O    O    O │
    │         {LABEL}        │
    │  O    O    O    O    O │
    │  O    O    O    O    O │
    │  O    O    O    O    O │
    │             o    o     │
    I believe Beau's code requires the keypad to be connected to the Propeller chip with very short wires to work correctly. I added 0.1uF capacitors to either the columns or the rows (but not both) to use the code with a keypad attached with longish wires.
    edited 2012-01-31 15:50
    Not unless you consider a pull-down (10K) and a normally-open button as extra circuitry.... ;)
    Duane Degn wrote: »
    John,
    Operation:
    will be returned.
    work.
    Schematic:
    board RevC.
           P7         P0
    │     oo ││││││││ o      │
    │  O    O    O    O    O │
    │  O    O    O    O    O │
    │         {LABEL}        │
    │  O    O    O    O    O │
    │  O    O    O    O    O │
    │  O    O    O    O    O │
    │             o    o     │
    This is great, I found this code before you referenced it to me, however, it still has been great, today I soldered some headers onto my new 4x4 keypad, plugged it DIRECTLY into the I/0 pins on the demo board, and it worked great!
    Thanks Beau!
    And thanks y'all :)
    -John
