Trying to make use of an old Basic Stamp
I have an old BS1 that I would like to use but I have the original parallel port cable. How can I hook this up to a USB port?
Thanks for any help.
Wayne
Wayne
http://www.parallax.com/Store/Accessories/CablesConverters/tabid/166/CategoryID/40/List/0/SortField/0/Level/a/ProductID/379/Default.aspx
Ooops - I just noticed you said parallel port - I hope you mean serial port, because that's what the above adaptor adapts to.
That makes it a serial connection. NOW you need a USB/serial adapter, such as the one MRM100 referenced.
I have tried two cheap USB-parallel converters to try to use my older Lexmark printer with USB computers, but neither worked, so I recommend the two-converter combination. I have personally tried it and it works using my ATEN USB adapter, so I'm sure the fine Parallax FTDI adapter will work as well.
