Portable Propeller Based Fibonacci Number Generator
Using a Basic Stamp version of a Fibonacci number generator, I created a Propeller version. It is able to generate Fibonacci numbers up to 1,836,311,903! It is designed to run off of a C3 (using only TV output and an LED hooked up to pin 15). The code can be easily modified to give output to the PST or VGA output.
EDIT: Rev 1.4 of code released.
The main differencs are as follows:
1) No "magic" numbers
2) Waits for the monitor to 'initalize' (our monitor takes several seconds to realize it is recieving a signal)
3) Increased timing duration
EDIT: Rev 1.5 of code released.
Adds a zero at the beginning of the sequence.
As an exercise can you modify your code such that it's biggest result is limited only by the memory available?
Although I guess the universe might end before it produces that result:)
Ok in this case you can run the loop till it fails then patch the number into your source. But what if the Prop were a 64 bit machine? It might take a long while to run and you may never be able to finish writing your program.
I was thinking in terms of the recursive fibo which, can take a long time, and forgot for a second that here it is done the easy way.
But my argument about that magic number still stands.
Now what about that big number version?
As we progress through the fibo sequence the numbers are getting bigger at an increasing rate. So aren't there a lot less steps between the biggest 32 bit fibo number and the biggest 64 bit one than we have to get to biggest 32 bitter? Given a 64 bit machine it should take less time to get there.
Now I don't mean to pick on you but we should get this right if we are going to do it at all.
The fibo sequence is 0, 1, 1, 2, 3, 5, 8...
By definition, the first two numbers in the Fibonacci sequence are 0 and 1, and each subsequent number is the sum of the previous two.
Your program omits the first zero.
Well I never.
The biggest 32 bit integer fibo is fibo(46) at 1836311903
The biggest 64 bit integer fibo is fibo(92) at 7540113804746346429
So there are 47 fibo's in 32 bits, and the next 32 bit gains us 46 more.
