What is the point of zero ohm shunts? — Parallax Forums
Martin_HMartin_H Posts: 4,051
edited 2012-01-29 07:56 in General Discussion
I recently soldered a pcb kit which included a few zero ohm shunts. They looked like resistors with a single black band and were used for things like bypassing the voltage regulator when using a regulated power supply.
What I found mysterious is why use them over a bit wire?
    edited 2012-01-27 18:56
    The reason for including them in a PCB layout is that they can be installed, when appropriate, with a pick-and-place machine. A small bit of wire cannot.
    edited 2012-01-27 19:01
    Thanks that makes sense.
    edited 2012-01-27 19:18
    Anybody else ever been told how "0-ohm resistors" (one band, black) were devised because "jumpers" as such weren't allowed on old mil-spec pcb's?
    [Jumper = No; 0Ω resistor = OK ]
    edited 2012-01-27 19:44
    If the circuit board doesn't have solder mask, there is a risk of a jumper wire shorting to the trace it's jumping. Zerohm's don't do that.
    Saw my first Zerohms in the docs for a HP2100A minicomputer circa 1974 in my father's physics lab. They were soldered in place to do peripheral configuration.
  • TubularTubular Posts: 4,767
    edited 2012-01-27 20:02
    They also buy a little extra flexibility with regard to number of layers. The ability to use 0 ohm shunts (and jump a track) can be the difference between having to fabricate 1 layer vs 2 layer pcbs.
    edited 2012-01-27 20:07
    http://www.ebay.com/itm/ZERO-OHM-Resistors-Lot-50-0-0-Ohm-Jumper-BONUS-/230736589626?pt=LH_DefaultDomain_0&hash=item35b8f8f33a
    Fifty zero ohm resistors costs ~$7. Sometimes less is more, more or less.
    So how do you figure the power rating (I squared R) for a zerohm? :)
  • MoskogMoskog Posts: 556
    edited 2012-01-28 01:02
    Could not resist, had to buy.
    No my homemade pcb's will look more professional with resistors instead of all the jumpers, haha!
  • ajwardajward Posts: 1,130
    edited 2012-01-28 02:07
    Thanks for the explanations! The first time I saw one of them was a wtf moment!
  • Mark_TMark_T Posts: 1,981
    edited 2012-01-28 05:23
    PJ Allen wrote: »
    That makes sense - in a high-vibration environment jumper links will work loose and fall off...
    edited 2012-01-28 08:27
    Fifty zero ohm resistors costs ~$7. ....
    That's simple. You equate Power to dollars per ohm.
  • RDL2004RDL2004 Posts: 2,554
    edited 2012-01-29 06:14
    I'm just curious, how does this work? Other than the small blob of plastic in the middle, there doesn't seem to be any difference between a jumper and a zero ohm resistor.
    edited 2012-01-29 06:21
    Do they fit ok? I was led to believe that they are......a little short.
    Sorry i'll get my coat.
    edited 2012-01-29 07:19
    RDL2004 wrote: »
    I am tempted to sacrifice one of them for science to see what is inside. My guess is that the wire goes straight through and the plastic is window dressing around it. I like the idea of using these as jumpers to avoid short against a trace as that has happened to me.
  • doggiedocdoggiedoc Posts: 2,250
    edited 2012-01-29 07:43
    skylight wrote: »
    I found that to be humorous.
    Martin_H wrote: »
    The alternative, assuming a piece of solid wire, is to cut a piece of nylon tubing or stripped insulation.
    Or, take the time to cut and strip the wire precisely. A lead forming tool is inexpensive enough and can aid the process.
