Transfering data wirelessly
Good Evening;
I am working on a project that involves a maxbotix sensor and a DS1602 (and a prop, of course). The project takes a range and a temp measurement once an hour and saves the data in upper 32k (and puts a time/date stamp on it). I can also download the data via USB and display in a CSV file. The project works perfectly. I would like the ability to download the data wirelessly every 3-4 weeks. The project is inside a centenary pole along a light rail path. The poles are about 50 feet from the road. I was thinking about using a pair of xbee units, but I seem to remember reading that the xbees are not good at transmitting a lot of data all at once (please correct me if I am wrong here). I have seen some good things about WIFLY. My question to you is... what kind of wireless units would be best for this situation? Thanks and have a great weekend.
A technician will drive to the pole and park to download the data (via PC laptop). The signal will have to travel about 50-100 feet. The signal does not have to be encrypted. The transmiter/reciever (in the pole) will be asleep until it is woken up by the other transmiter/reciever (attached to the laptop). Then the data can be downloaded from that point.
For what you're describing, XBee probably would be a reasonable way to go. You would probably do well to look at SparkFun's Wireless Buying Guide.
The main down side to these modules is they are more complicated to communicate with than XBees. I've written a driver for the Propeller to use these devices so it shouldn't be too hard to use them.
