New proximity sensor, good fit for Propeller — Parallax Forums
RaymanRayman Posts: 16,456
edited 2012-02-06 16:35 in Propeller 1
Just wanted to mention a new digital proximity sensor, Prox1...
It's based on the Osram SFH 7741 IR proximity sensor.
Has a range of 30 mm and a digital output.
Rated for 2.4 to 3.6 volts, so it's perfect for the Propeller.
The output is open drain with 100k pullup resistor and abs. max voltage is 6 VDC, so I actually use them at 5 VDC on a servo header and it works fine.
Comes with a servo extension cable that you can cut in have and then use either male or female end to connect to your circuit.
I'm using four of them on a Sparkfun Magician chassis bot. Three for wall avoidance and one for looking at the floor:
619 x 430 - 274K
1024 x 768 - 80K
    edited 2012-01-27 11:29
    Rayman wrote: »
    Looks great! I'm especially impressed by its "aspect ratio" (or whatever it should be called), how far it can detect vs. it's overall size.
    edited 2012-01-27 12:14
    After looking through some of the literature, I think these have a range of about 3cm. Is that enough to keep from bumping into wall?
  • RaymanRayman Posts: 16,456
    edited 2012-01-27 12:18
    Yes, check out this video (from this thread):
    Watch Merlin robot use optical sensors to avoid hitting the wall:
    http://www.youtube.com/watch?v=N-JmOayldJ4
    edited 2012-01-27 12:29
    Rayman wrote: »
    That's very cool!
    Duane
    edited 2012-01-27 13:00
    I recently caught bits of an artical on tv about a model of a rats snout. it had loads of "wiskers" to do the proximity sensing and map out its enviroment. Unfortunately there was too much noise going on to catch any details
    edited 2012-01-27 15:06
    Rayman wrote: »
    Watch Merlin robot use optical sensors to avoid hitting the wall:...
    Looks great. What about the sensor you have on the front and looking down? Does that avoid cliffs?
    edited 2012-01-27 15:19
    I think it could, that was the idea... But, my hardwood floor is a bad color for this...
    The full 3 cm range is for white. It's more like 1.5 cm or less for dark things.
    Anyway, it'd work to detect the floor if I moved it down lower, closer to the floor.
    Right now, it's more like an "object on the floor" detector...
    BTW: I think it would be good for a line follower too. White tape on my hardwood should work...
  • GeorgeCollinsGeorgeCollins Posts: 132
    edited 2012-02-06 13:57
    I just wanted to say that I spent this weekend testing these sensors at 3.3v and 5v and they work very well. They were easy to set up and quite reliable. I plan to stick them on a robot and hopefully I can post a video. Thumbs up!
    Thanks George! Glad they're working for you.
    In hindsight, I wish I had the output pin on the outside, so it'd match a servo header.
    May have to change that for the next batch...
    I still think of 5V operation as a bit experimental. Seems to work fine and it's below the "Absolute Max."
    Just a little worried about lifetime... I should power one up 24/7 just to make sure it can take it for a long time...
