DVI Input — Parallax Forums
DVI Input
rapscaLLionrapscaLLion Posts: 75
edited 2012-01-27 11:25 in Propeller 1
Hi all,
I have a DVI signal (presumably DVI-D), which I want to pass into the prop in order to capture certain relevant 32 bit pixel colours (say the first 200, up to 30 times per second). Is this even remotely conceivable with the Prop? If the DVI signal speed is just over 25MHz, it should be readable by the Prop, no? And will this eat up more than one cog?
This is purely hypothetical at the moment, but I would appreciate your thoughts on this! :)
  • RaymanRayman Posts: 16,457
    edited 2012-01-27 06:24
    I think it is not possibe because DVI runs at a very high frequency, higher than the Prop...
    But, you could use a DVI decoder chip to do it...
  • groggorygroggory Posts: 205
    what are you planning on doing with the dvi data stream? (just out of curiosity)
