You can delete a duplicate thread with only your first message by deleting the message. Your duplicates have been removed.
Regarding your problem, you need to give more information. You might start by describing what you're trying to do, describing your circuit, maybe including a schematic. If there's a program, you should include a listing. Use the [ code ] and [ /code ] tags surrounding the code (without the extra spaces) to prevent the leading spaces from being removed. Describe what you've done to this collection of parts and describe what happened when you did it.
