Decimal to Integer conversion — Parallax Forums
g3cwig3cwi Posts: 262
edited 2012-01-26 12:56 in Propeller 1
Hi all
New to this but I want to set a loop to repeat a number of times based on a calculation. The calculation produces a decimal value and the repeat command appears to need an integer. I tried "Round" but that did not help. Any ideas?
Richard
    edited 2012-01-26 12:07
    There's a technique known as "pseudoreal". You basicly use a multiplier such as 100 to do your computations and just keep in mind that your number is really one hundreth of the value in your variable.
    If you could be more specific about what you what to do we probably better help. What calculation produces which decimal value?
  • g3cwig3cwi Posts: 262
    edited 2012-01-26 12:13
    Hi Duane
    It is an audio beeper and I want to use the number of cycles to determine the length of the beep accurately:
    Cycles := ((1/Freq)*(Duration*1000)) 'Calculate the number of cycles for chosen duration
    repeat Cycles
    !outa[Pin] ' Toggle I/O pin
    waitcnt(ClkFreq/Freq + cnt) ' Delay here sets the frequency
    Cheers
    Richard
    edited 2012-01-26 12:34
    "1/Freq" will likely always be zero.
    Instead use:
    Cycles := (Duration*1000) / Freq 'Calculate the number of cycles for chosen duration
    You want to get in the habit of thinking of intermediate values.
    Follow this link to learn how to post code in the forum.
    edited 2012-01-26 12:46
    Thanks Duane
    That's a useful tip!
    Regards
    Richard
    Richard,
    Your welcome.
    By the way, welcome to the forum.
    Duane
