Transformer or inductor?
Im trying to understand what T2 is doing in this schematic.
It does not look like it is being used as a transformer. It looks like it is being used as a pair of inductors. I will probably build this and try individual inductors and see what the results are.
This circuit was designed in the mid 1990s. The company does support the equipment and Im building replacement boards. I can copy a circuit and not know how it works, but I like to know.
The failure of the control board, not generally involved with this circuit, causes many burnt lands and destroyed components.
Thanks for the insight.
I believe after looking at the circuit that the T2 component is being used as an inductor in an LC tank circuit. Note that if you redrew the circuit, you would find that you have an LC tank circuit placed across the unfiltered full wave circuit formed by the rectifiers. If your meter reads inductance, it would be interesting to see how the pwm frequency stacks up against the calculated resonant frequency of the tank. Maybe clip the cap and see what the effect on the output is. Looks like the tank circuits are being used as high frequency filtering.
Out of curiosity, is the isolated power supply being used for biasing high power switching circuits?
Frank Freedman
eh, time to go get my prescription filled. I guess Lens Crafters or Costco. Who ever turns em faster. Thought the filter cap was across the T2 winding........
As Homey would say mmmmmmmmmmm doughnut... er, I mean DDDOOOOOOHHHH!!!!!!!!
FF
Can one post chars using overstrike on here??
One of the 20 volts is regulated down to 15 volts to be used by the computer interface.
The other 20 volts is used by the control section of a power factor circuit and a buck controller.
The output of the supply is 150 volts DC at 44 amps.
FF
