necesito ayuda porque no puedo controlar los servos, si alguien me puede asesorar para mantener los servos en diferentes posiciones y pueda mantener algunos servos en una posici
I need help because I can not control the servos, if anyone can advise me to keep the servos in different positions and can keep some servos servo position while others move.
because when the first servo move that would be the 1 dof, then to move the second servo stops the first servo tends to return the first servo signal as if lost.
so I need suggestions
¿Qual microcontrolador está usando para controlar los servos?
What micro controller are you using to control the servos?
