rctime and lm35??
is there any schematics that could show me how to connect an lm35 to an rc circuit so that i could connect it to a bs2? do i replace the pot with the temp sensor?? I want the bs2 to alert me if the temp. is approaching 0 degrees celsius. thanks in advance.. anybody with any code regarding this problem would be really appreciated
See Tracy Allen's info at http://www.emesystems.com/OL2heat.htm#TF_LM34 and also http://forums.parallax.com/showthread.php?135361-ADC0834-amp-LM34-vs.-Offset&highlight=ds18b20
You could RCtime a thermistor directly, but you're going to need an op amp or ADC to use that particular sensor.
The voltage output approaching 0 degrees C is very low, but you could run that into a 99-cent comparator (LM339 or equiv), using a trimpot to set a reference voltage. The comparator snaps on when the sensor voltage drops below the reference voltage, and that output can trigger your Stamp or other electronics directly.
