Bad IR diode? Not so fast
Working on my Boe-Bot I was trying to build the IR circuit from chapter 7 of the book. I soon discovered that it didn't work. I double checked the circuit, and resistors, to be sure I had done it right. But it still didn't work. I then took one of my Television remotes, pointed it at the circuit, and the ones and zeros started changing. I had, in my stupidity, mixed the IR diodes in with some clear diodes. I discovered this when I pluged a clear diode into the circuit and it began to flash. Another indicator that the circuit, and the program, were working. So..... I learned that with a television remote, and a clear diode, I could trouble shoot my IR circuits.
Cheap digital cameras omit an IR filter so perform best for this - phones usually good. Top-end DSLR is not so good!
