Switching to Autonomous Mode - New to Robotics Question
Hello All.
I'm new to robotics. But I have managed to build a robot with receiver (Spektrum) controlled solely by the transmitter ( Spektrum DX6i). Now that I have that working I'm going to start the processor (Stamp) work/programming with sensors and so on.
How do you switch from transmitter to autonomous mode and back again?
I apologize if this is a basic question.
Any help will be appreciated.
Thanks (in advance).
The robot would then need a way of connecting the data lines of your servos and other equipment to the Stamp instead of the radio receiver. This could be done with double throw relays.
How many of the radio's channels does the robot use? You may run into trouble monitoring sensors and driving a bunch of servos within the 20ms refresh period.
With the Propeller, you'd have the Propeller monitor the signal line and just pass the same signal on unless it's in autonomous mode. Myself and a bunch of other people have done this with the Prop.
BTW, This isn't a basic question. I don't think this is a simple task (at least not compared with blinking a LED).
Yes, I thought about the DPDT switch at least manually...lol.
The robot is currently using four switches which will cut it down to two or three when I introduce the Stamp or Propeller processor.
I also have the Propeller processor which I'm slowly learning in parallel to doing this project. Is there any documentation and/or links online to help explain how to pass the signal through the Propeller chip like you all have done?
Thanks for the information.
Thanks all. I'll see you on the next post.
